| diyAudio Sponsor | ||
#31 |
No, just divide 1.25 volts by the desired current to define the current-setting resistor value. I see no reason why the current couldn't go as high as 1.5 amps, although this resistor gets quite small in ohmic value. I've used them happily up to 50mA in tube cathodes.
Edit: Oops - Just re-read you post and you did say "minimum" current, not "maximum". Yes, you are correct; there is a minimum current, that is often stated as 10mA, but in fact can be less if you carefully study the LM317 data sheets for the temperatures and voltages likely to be encountered. So it wouldn't be used to bias a 12AX7, but I tend to pull a lot of current through tubes like a 6DJ8 or 12B4 to get the transconductance up, so this limitation is not a problem for me generally. For my CD output stage application with a 12B4, I run almost 30mA through each tube to achieve the "text book" 1K plate resistance.
Brian |
#32 | |
I'm glad that you find your preffered line stage I'm completely (spell spelll spellll??) aware of arguments and metodology argumented in yours (above) lines,and I also tried all that stuff in my tube beginings ( senturies ago what is my preffered type of supply and type of line stage you can see if you click at www button on bottom of my post.... each approach have own arguments ,but only builder's taste is finally responsible for finall decision hehe-to each his own cheers!
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#33 |
Would anybody be so kind as to spoonfeed me the gain of the line stage in question? TIA
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#34 | |
#35 |
I was encouraged by our forum members especially Brett (Thanks Brett) and built a 12B4A line stage. It sounded wonderful. I initially used some lower quality parts. How it sounded almost completely depended on how good the filter caps I used. This was what I initially had: 380-0-380V Tx => Sovtek 5AR4 => 10H => 470uF (H.Q.) => (split into 2 channels) R => 330uF (L.Q. cap). I built a LM317 regulated heater supply. I didn't buy any caps and just used what I had on hands. The sound was initially messy and hummed quit a bit. I found out that the 330uF caps were not good at all and replaced them with the Panasonic ED 100uF. The sound became pretty good but the hum was still there. Replaced the 100uF with ICW Clarity Cap (Polypropylene) 2 x 20uF = 40uF on each channel the HF sound was very satisfying but the bass was severely lacking. It hummed quite loudly and I couldn't enjoy the music. I then paralleled the 100uF with one ICW MKP 20uF for each channel and started enjoying the music since. It still had a bit of hum. The latest change was to use the 330uF low quality cap as the first cap, like this: 10H => 300uF (L.Q.) => R => 470uF (H.Q.) (split to 2 channels) => R => 100uF (H.Q.) + 20uF (MKP). What was the sound? still a touch of messiness, still a bit of hum, but overall - Excellent. I most certainly believe that sound wise it beats the Audio Research xxxx preamp my friend has that I liked so much which triggered me to look into building a tube preamp. Then one of the tubes (Industrial grade Westinghouse) started making more and more noise (like firewood burning sort of cracking sound). Is that microphonic? leakage? I am pretty sure it was the tube because I swapped the tubes and the noise only came in the channel with the bad tube. It got so bad so I decided to shut it down and rebuild it. I have ordered 4 x GE JAN Mil Spec 12B4A and 2 x Sylvania Mil Spec 12B4A and they will arrive at any time from now. I will compare their sound. I have bought 2 x 200uF Solen MKP for the last cap of the power supply. I am getting a new custom made Toroidal Tx to replace the old E.I. transformer as it hummed and gots VERY HOT! I am also replacing the 5AR4 because I don't like the preamp to run so hot with 5V x 2A = 10W wasted in rectification! I decided to make it mono stereo and have ordered 8 x UF4007 and the 8 x 0.01uF 1000V ceramic caps and will make 2 snubbers for the secondary wirings. 2 x 10H hammond chokes will arrive tomorrow. All filter capacitors are Panasonic TSHA and TSHB except the last caps being Solen MKP. It will be like this (mono): Tx 350V => Snubber => UF4007 => 10H => 100uF => 270R => 220uF => 270R => 470uF => 270R => 200uF (Solen). It will give me 300VDC running on 25mA + 2mA (breeder) with the AC ripples reduced to 0.02mA. I have some questions about the layout of the preamp. I have one 2mm thick steel sheet to shield the Tx and chokes from the circuit in the steel chassis. How effective is such a shield? Can it eliminate (or reduce to an acceptable level of) RFI? If it can shield the RFI from the Tx and chokes, the energy must go somewhere. I guess it would be turned into currents in the chassis. How to do deal with it? I think a star ground should help. Another question is whether I should make another 2 steel sheets and install them between the Tx and the 1st choke, and between the 1st choke and the 2nd choke. I may not have sufficient space to orient the chokes 90deg from each other. What is the best way to do it? This is the new layout: Thanks and regards, Bill |
#36 |
My two cents about the 12b4 linestage:
I built one following the schematic on diyparadise.com; using 12k anode resistor and 260V B+. Power supply is dual mono, capacitor input double pi filter with European Rgn1064 mesh anode rectifiers (electrically comparable to 5y3 but the mesh version is a big step upwards from anything else) - Sound is excellent; quite close to what Yeo describes: Prominent high tones; amazing neutrality + gain in soundstage; especially the increased depth struck me. Power supply capacitors are all motor-run caps (pio) which are in every amp a big improvement on electrolytics. Power supply is unregulated and I plan to keep it that way in the definitive version as there aren't too many arguments (soundwise) for a regulated ps. The 0,33µF coupling caps on the schematic are big-time overkill; I work with 0,056 Russian military teflon-in-oil capacitors (still around 7hz cut-off so you won't miss anything unless your speakers are huge tml's or big subwoofers + you gain everything by using smaller, faster and better caps). I'm planning to play with the loadlines soon; altering B+ and anode resistor & maybe cathode resistor. Will keep you posted if I find any audible improvements on the current version. Simon |
#37 |
That's 7Hz if you never connect the line stage to anything and the cap only sees the 470K grounding resistor that is part of the line stage. If you drive a power amp with a 100K input resistance (pretty high these days), you'll see a -3dB point of about 35Hz. Not good. If you load it with 20K (which the 12B4 could drive), you'd see a roll-off at about 140Hz. I think 0.056uF is just too low to advise for general use in the output of a line stage, as good sounding as it might be. I think 0.33uF is marginal too.
Brian |
#38 |
I agree with Brian on that. I am at 2mfd right now and I intend to go to 5 mfd when the caps arrive... Multicap PPMFX
Mark |
#39 |
I'll have to do a little listening-test to check it out. Is it so very different for a preamp? At first I used a 0,47 cap; then switching to the 0,056 cap I didn't notice a more rolled-off low-end. My high-eff. speakers only reach around 60hz but I did a short test on my transmissionlines (around 25hz low-end) and it sounded okay - didn't do an a/b test though. Could you tell me how to calculate / measure the input impedance of a power amp? And how to insert it into the formula for calculating the -3db point of the preamp? I'll also give it a try with a pair of 5µF caps on the transmissionlines; if you guys are right the audible difference should be HUGE...
#40 |
Klimon,
Even if your speakers don't go low enough for you to notice a huge difference in level with an undersized coupling cap, a too-small cap will introduce a phase shift well up into the mid-bass that might smear the "presence" and "air" that truly deep bass response can provide. Granted, the high frequency response of a small cap might/should be better. Perhaps you could experiment with bypassing a larger film cap with your nice 0.056uF Teflon caps. Input R (call it “Rin”) is probably easier to calculate than it is to measure unless you are very skilled and equipped to make these test measurements. If you will post a schematic of the front end of your power amp (or whatever the 12B4 will directly drive), we can help you to calculate it. Once we know your power amp’s Rin we can calculate the -3dB roll-off frequency as follows: f-3db = 1/(2*pi*C*Rtotal), where Rtotal = [(Rin*470K)/(Rin+470K)] + 1000. The last resistance value (1000 ohms) accounts for the approximate output resistance of the 12B4 stage and is so low compared to the other resistances that you can usually safely ignore it.
Brian |
| Page generated in 0.15546 seconds (82.52% PHP - 17.48% MySQL) with 11 queries |
