Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... - Page 21 - diyAudio
Old 4th April 2006, 11:49 PM   #201
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
which schematic did you use? the original, the one with ccs?
Old 5th April 2006, 12:17 AM   #202
lawbadman's Avatar
This one:
http://www.diyaudio.com/forums/showt...926#post776926
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/lawbadman.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Danasoft - <a href="http://www.danasoft.com">For Backgrounds and Layouts</a></p></div>
Old 5th April 2006, 12:35 AM   #203
Brian Beck's Avatar
Remember, that post was for a CD output stage. I said it could be ADAPTED for line stage use. You wouldn't use the resistor divider and LCR filter before the grid in a line stage. Did you put all those parts in? You would just connect the grid to a volume control wiper (I'd add a 1MEG safety resistor from grid to ground and maybe a grid stopper of 100 ohms).
You should measure gain of 5X to 6X (around 15 dB). And yes, a 10 W resistor will be very hot with 5 watts dissipated in it. That's normal. I would make sure that it has plenty of air flow and is not right next to other components that it could cook.
Brian
Old 5th April 2006, 12:46 AM   #204
If it's not too much hassle, may I suggest you try this- http://www.diyaudio.com/forums/showt...678#post821678
That's what I use and sounds just right and gain just right for my 45, 2A3 and 300B amps.
Old 5th April 2006, 01:15 AM   #205
lawbadman's Avatar
Thanks for the replies guys.
Brian, I did remove all of the filtering components, I have connected a 220k resistor from grid to ground, thats it nothing more.
arnoldc, if I use the schematic that you showed, how would I incorporate the CCS?
BTW what is the ouput impedance of the linestage?
This just hit me, I am presently using headphones (Senn HD 580) with the circuit, is that why I have low gain?
Lawrence
Old 5th April 2006, 01:38 AM   #206
Hi Lawrence,
replace the cathode resistor with the CCS from Brian. But my 12B4 is on the low side- 17mA.
ooops! i think you need more drive
Old 5th April 2006, 04:07 AM   #207
Brian Beck's Avatar
As Arnold said, that would be your problem! IIRC, those phones have an impedance of about 300 ohms. Most linestages will not drive them at all. The output Z of my circuit will be about 900 ohms. That makes a divider ratio of 300/(300+900) or about 1/4. That would eliminate most of the gain of the tube, increase distortion enormously, and cause a bass roll-off because the coupling cap isn't sized for 300 ohms. You need a headphone amp, many of which are described in this forum.
Brian
Old 8th April 2006, 05:18 AM   #208
Pulled out the scope and signal generator and took the following pics of the result from my 12B4 preamp.
Old 8th April 2006, 07:48 AM   #209
ashok's Avatar
You need to set your oscillator. It's not set for 50 : 50 spacing. There must be a pot on the front panel.
I must check out what I get on my 12B4A .
Anybody have any idea if there is any difference between RCA, GE and Zenith brands ?
Thanks,
Cheers.
AM
Old 10th April 2006, 12:39 AM   #210
ashok, you're right. i just found the adjustment- it's the same button to select sine/square- it says symmetry (turn for symmetry).
thanks!
Copyright 1999-2017 diyAudio
