Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... - Page 13 - diyAudio
Old 24th December 2005, 07:33 AM   #121
Brian & "Mr. Tube"
Thanks for your insights . I'll try the CCS both above and below the tube, but not both.
Ho, Ho, Ho! And, Merry Christmas to all!
Old 24th December 2005, 09:45 PM   #122
sunrise's Avatar
Send a message via ICQ to sunrise
it is a real must to paralel few capacitors in the cathode of the tube in the paralel of the LM317.... otherwise - no good sound... i have learned that now....
best regards and merry chritmass for everyone
when you burn it - burn it good
Old 26th December 2005, 10:33 PM   #123
Here is yet another great article with design plans for what appears to be a very good tube regulator circuit. Starts off very basic and then ends up pretty darn complicated!
Link
Mark
Old 29th December 2005, 01:21 AM   #124
Default 300V B+
If using the Brian Beck circuit with a 300V B+ would this degrade the sound much and/or will the circuit need to be changed?
Hope some one can help.
Martin
Old 29th December 2005, 03:33 PM   #125
Brian Beck's Avatar
If you're asking about dropping the B+ from 320 volts to 300 volts, then I think it will still work OK. The plate-to-cathode voltage will drop to about 100 volts, but the plate curves still look fairly linear at that point assuming line-stage voltage swing levels (2 volts rms or so). You could back down on plate current a bit by putting a larger resistor in the LM317 circuit (say, a 47 ohm value) and use the freed-up voltage to split between a larger plate load resistor and/or a larger plate voltage operating point. How much all this is audible is debatable. The point is that, within limits, this circuit is not THAT critical.
Brian
Old 29th December 2005, 03:59 PM   #126
Default Brian Beck
Thanks for the answer I was talking about dropping the B+ from 320V to 300V. I think I will try this circuit whenever I get all the other things that are lined up finished.
Martin
Old 30th December 2005, 04:52 AM   #127
diyAudio Senior Member
fdegrove's Avatar
A 300VDC PSU you said?
Here you go:
Frank
Old 30th December 2005, 07:09 PM   #128
Here you go:
Quite fun it was actually this PSU I wanted to try at some time as I also would like to try your 12bh7a circuit with it. Though I wanted to be able to try the 12b4a aswell as I am not sure if I can live without the gain, but only a test will show me that.
Martin
Old 30th December 2005, 09:48 PM   #129
sunrise's Avatar
hi guys----happy new year first of all -
i would like that somebody here explains nice and easy what will happen if i accidently pull out the 12b4 while preamp and amplifier are working......
also - another thing.....
i have made my 12b4 preamp with 26mA and 130V on the anode of the tube... i have 4k7 resistor in the plate.... this is not quite the line stage from our Brian but it is working nice... also i have got no strange treble i was having problems with (before i have paraleled the cathode capacitor with the smaller one MCap-Mundorf 1uF/400V).... - - - - BUT - - - , i have perceived big humming when the preamplifier is turning on... this humming is gone after arround 20 seconds..... what is happening.... probably the tubes but i am not sure and this is not comfortable to listen to when i turn the preamplifier on....
best regards and have fun during new years evening......
sunny
Old 30th December 2005, 10:14 PM   #130
fdegrove's Avatar
Nice and easy, he?
I don't think I'd call "accidentally" pulling a tube with the gear up and running errrrr........An accident.
Apart from some noise nothing much will happen but I'd advise seeing some kind of doctor if you have habits like that.............
Mute switch ring a bell?
Maybe you heard about tubes needing a little time to warm up? Like about twenty seconds perhaps?
Sunrise, maybe you should put that Tequila bottle back where you found it........
Ciao,
Frank
Copyright 1999-2017 diyAudio
