Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....
Old 22nd August 2012, 04:53 PM   #791
6L6 is offline 6L6  United States
6L6's Avatar
Bump.
I'm breadboarding a 12B4 preamp and want this thread towards the top where it can be found easily.
Old 22nd August 2012, 07:43 PM   #792
coffeedj is offline coffeedj  United States
coffeedj's Avatar
Send a message via MSN to coffeedj
Default Some thoughts
One point to note on the 12B4 power. It really helps drive the baseline noise floor to zero if you use a separate power supply. DC heaters are also a good idie.
"Make me to know the end of my days" King David
Old 22nd August 2012, 09:52 PM   #793
6L6's Avatar
The plan is CRCLC with a 20H choke and lots of capacitance.
I will try DC heaters as well. Thanks for the tip!
Old 22nd August 2012, 11:16 PM   #794
vconsumer is offline vconsumer  United States
I have had a half-breadboarded, half-finished build of Eli Duttman's 12B4 amp in my system for the last few weeks. I built it on two chasses and converted to DC heaters. I am very pleased.
Old 29th August 2015, 06:38 AM   #795
jcdrisc is offline jcdrisc  Australia
Mark, here is my take on a 12B4 linestage.
Broskie's TUBECAD is well worth the money
Old 29th August 2015, 06:57 AM   #796
jazbo8 is offline jazbo8
jazbo8's Avatar
I think there is an error in the Vmax out on your report, such large difference between the + and - swing suggests relatively high distortion.
Old 29th August 2015, 09:31 AM   #797
mach1 is offline mach1  Australia
Banned
That scenario would require approx 25v input: not a very likely condition to be encountered in reality. At normal input levels around 2v the swing would be confined to an area of the plate curves where the +ve and -ve negative excursions would be far closer.
Old 29th August 2015, 09:40 AM   #798
jazbo8's Avatar
We must have missed school that day, the whole thread is about using the 12B4 as a line amp...
Old 1st September 2015, 02:10 AM   #799
Default noisy gas tubes
I make again the firm assertion that ALL gas tube regulators are noisy, fdegrove.
Look at any Tek tube scope psu. Tek uses a 1M/100n filter before the grid of the error amp to get rid of all the hash. Why any amp designer uses them is beyond my comprehension. I enclose here a noise generator from Scroggie's book where an 85A1 is the noise source
Old 1st September 2015, 03:05 AM   #800
Mark Allen is offline Mark Allen  United States
All of my 12B4 builds used stacked gas regulators and the noise floor was exceptionally low. Perhaps if this was a high gain circuit like a tape head or phono stage it would matter a lot. Not the case here. In fact my bench H-V supply is an old Eico tube supply and it is even exceptionally quiet, no,worse than a similar range H-V bench supply I have.
Mark
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....Hide this!Advertise here!
