Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... - Page 51 - diyAudio
Old 22nd September 2006, 01:15 PM   #501
speaker is offline speaker  United States
speaker's Avatar
Originally posted by staggerlee
$17,000! I hope it comes with K-Y!!!
Hey, at least they include the 274B rectumfryer!
Old 23rd September 2006, 03:56 AM   #502
mach1 is offline mach1  Australia
Banned
Please reccomend a choke if you would.... No, I won't try an output tranny if you held a .357 to my head!
Try a Handmade Electronics H3007 (60H @30ma): they mate very well with the 12B4 and won't break the bank.
pm
Old 23rd September 2006, 05:47 AM   #503
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Does anyone have a schematic of a tube regulator circuit for the 12b4?
I have 2 OA2 tubes on hand, can they be used?
Can anyone point me to the datasheet for the oa2?
Lawrence
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/lawbadman.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Danasoft - <a href="http://www.danasoft.com">For Backgrounds and Layouts</a></p></div>
Old 23rd September 2006, 10:10 AM   #504
pengboon is offline pengboon  Singapore
Originally posted by Mark A. Gulbrandsen
I have no problem trying a choke in there, thats a sensible thing to try. I also have not tried a solid state regulator at the plate either. Someone had reccomended the IXYS type....
Mark
Mark, do give the plate chokes a try. I have, and I ain't removing them anytime soon! I am using 100H 50mA. I have to add "wider and deeper soundstage" to what Zen_mod has mentioned too...
I had a humming on one channel initially and just could not figure it out. Until I moved my PSU choke. Orientation didn't matter, physical distance did...
Old 23rd September 2006, 10:14 AM   #505
Are you going to use plate chokes? If you are, then you can use 1 OA2 on each side giving 150V regulation. If not, then you're going to need 300V and (recommended) 2 OA2s per channel (total of 4). Look for Zen_mod's schematic some posts ago...
Old 23rd September 2006, 02:56 PM   #506
lawbadman's Avatar
I guess I dont understand how tube regulators work, but why would I need two per channel? Dont they work like zener diodes???
Old 23rd September 2006, 03:24 PM   #507
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
They do work like zeners.... You have to stack them in series to get the needed voltage.
I will try plate chokes as soon as time permits. The KSA-100 thread is comming back alive too and I have very limited time....
Mark
KSA-100 WIKI
Old 23rd September 2006, 04:23 PM   #508
One 0A2 with regulate to 150V, so to get 300V, you will need 2 stacked together as Mark mentioned. If you use plate chokes, you need only one for the required 150V.
Old 5th October 2006, 12:41 AM   #509
On the topic of plate chokes, what are the sonic differences between a setup using plate choke and that which is using a OPT? I guess plate chokes still has the effect of the output capacitor, and higher output impedance?
Old 5th October 2006, 12:47 AM   #510
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Mark
Unlike Zeners they need a higher voltage to fire up, after that they drop voltage down to a regulated level. Slightly different resistors across them is the way to fire them up one by one and make resulting fire-up voltage less, if you connect them in series.
The Devil is not so terrible as his math model is!
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
