Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....
Old 17th September 2006, 11:10 PM   #481
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by Mark A. Gulbrandsen
Will it ever all be in just one chassis? Doubtful since I'm always trying something new in the very little spare time I have these days.
Mark
where you'll put chokes in it ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th September 2006, 12:59 AM   #482
jasonb84 is offline jasonb84  Canada
Has anyone run this tube at class A with a plate of 150V/34mA as per the datasheet? Or is it felt that 120V/~24-28mA sounds best.
Regarding the plate choke and single OD3. Zen's schematic redraw has a 100+uf cap to ground, followed by 1k67/10W into the two OD3. These draw 30mA, they are in series so am I correct in thinking a single will also draw 30mA leaving the difference to go to the plate? Is there any need for voltage dropping resistors at all, ie could the PS be directly connected to the regulator if the supply voltage is low enough?
Is it now established that a good sounding way to go is to load up the PS with lots of iron, feed the single gas regulator and then use a plate choke to drop the last bit of voltage down to the plate? A choke rated at anything above 60mA will work but what does the inductance rating effect? If I'm given the DCR of the choke then I could work my way backwards to the supply.
Old 18th September 2006, 01:15 AM   #483
Zen Mod's Avatar
hehe
I dunno;
I didn't play with 12B4 at all (you can't count at least 10 another similar and non similar toobz in my WOT prototype )
and question is?
ok
I'll stop joking
if you use choke as anode load-nice starting point for anode voltage is in ballpark of 150 V;
assuming that your choke will not have more than ,say, 10V of voltage drop across it-you can freely discount that voltage drop in entire situation;anyway-toobz are made in some range of characteristics and you'll hardly find exactly replicated ones from manufacturer's data.
use power xformer,rectifier and smoothing mechanismus whatever you like,put resistor and gas toob ,no cap cross gas toob (for start) ,calculate that series resistor for sum current of say 55 to 60 mA ,put choke on top of anode ,cap on anode and listen
after that you can measure exact voltages,try to change few bits and bobs to make exact voltages,and you probably will not hear any change if you are in range of 10% of estimated values;
that's not RIAA EQ ;topology is more important than ohm or two here and there;
one possible element for improvement can be CCS instead series resistor (preceding gass regulator toob)
try it on breathboard first
you ca always buy few pcbs from P10 or Geek
Old 18th September 2006, 01:22 AM   #484
Geek is offline Geek
Geek's Avatar
What point for "best sound" is sooooo subjective
From the curves, a 150V @ 24-28mA has great linearity.
Old 18th September 2006, 01:35 AM   #485
Zen Mod's Avatar
think again;
voltage drop across this resistor is ,in fact, voltage range for regulation ;
no surplus,no regulation
Old 18th September 2006, 02:09 AM   #486
Thank you Zen for all the clarification. Now to source some parts and start building.
What is the range in henries that would be suitable for the anode choke?
Old 18th September 2006, 02:22 AM   #487
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
$17,000! I hope it comes with K-Y!!!
Hey, mine is bult from the best parts available and theirs is not even built with ceramic/silver Tektronix terminal strips nor does it have the best available remote controled attenuator built into it. Ha... not only should it come with a gallon of K-Y but also with a 44 magnum to finish your self off after you discover on this thread that you can build it even better for less than 200 bucks!
Mark
KSA-100 WIKI
Old 18th September 2006, 02:37 AM   #488
To pose the question again in case no one picked up on it. I count 1 274B rectifier, 2 12B4A's, 4 OD3 regualtors but I still can't figure out the pair in front. They look to be a similar shape to the OD3 but emit a typical orange glow rather than the unique purple.
Anyone know what they are?
Old 18th September 2006, 03:19 AM   #489
Forgot to add:
What is the expected life of these tubes in this particular circuit? Should we be stocking up on an extra pair or two?
Old 18th September 2006, 03:37 AM   #490
pengboon is offline pengboon  Singapore
Mark
Hahaha... I couldn't stop laughing when I read this !!!
Hey Mark, yours doesn't come with the orange glow toobs!!
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
