Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....
Old 11th December 2005, 08:32 PM   #91
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
Thanks for the link Planet 10!! I had read stuff on that site a couple of years back but had forgotten all about it. 125 euro for the kit???? Pretty pricy but could be done for less by DIY. I would be more tempted to buy the book and build it myself.... the book would be good to have anyway.
Thanks,
Mark
Old 11th December 2005, 08:35 PM   #92
kooltubes is offline kooltubes  France
You can buy a tube regulator pcb for $20 (no tubes though) it's a Lite audio you will need an EF86 and an El 84 or EL86; the board comes with a filament regulator. Check on ebay or www.liteaudio.com
Old 11th December 2005, 08:55 PM   #93
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Yes... it is a hoot, gives some solid info & lays out AWs philosophy. Even having the book, i'd probably buy the reg kit myself...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th December 2005, 09:36 PM   #94
Aw, thats no fun..... Kits are way too easy..... Unless there are some special spec'd out parts I can't see why not to build it DIY?
I have one of those boards here. I don't think it can supply 60ma of current for both channels, so you would probably require one board per channel. The board by the way is extremely nice!!
Mark
Old 11th December 2005, 09:40 PM   #95
Looneytunes is offline Looneytunes  United States
Thanks everyone for the great power supply discussion. I definitely have some research (and a lot of catching-up) to do.
From Dave:
...You can buy the book (Preamp Cookbook -- one of my top 3 recommended tube books)...
Dave, I'll definitely get the Cookbook. What are your other two top books? Does anyone have any other "highly-recommendeds" to add to the list?
I'll probably start with Brian's or Kool's power supply. Lots of iron, but by the time I get the parts , I should have a basic understanding of what is going on. Can anyone suggest a good source (and manufacturer) of pio capacitors? Is quality critical considering where the parts are used?
From Bryan:
I do have a very slight amount of hum, but this is caused by the physical proximity of all the iron of the PS chassis ...
Bryan, how far would you recommend separating the tranny & chokes to get rid of this hum? Also (and please excuse the NewB question), but I remember reading that all of the iron needs to be rotated 90 degrees from each other to minimize coupling. If I remember correctly, your design places a tranny plus 2 chokes (per channel) on the power supply box. Can I "decouple" (I hope this is the right word) the three pieces by rotating them by 90 degrees over all three axes?
From Evan:
Any thoughts as to stuff I should read before doing this project besides the newbie pages?
Evan, I found the "Online Tube Audio Resource Guide" a virtual treasure trove of information. If you haven't found it already, you can find it at: http://www.tubeseller.com/docs/tube_links.pdf. You'll even find links to complete texts there.
Thanks to everyone for the help and great information.
Wynn
Old 11th December 2005, 09:58 PM   #96
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
http://geek.scorpiorising.ca/GeeK_Zo...php?board=33.0
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th December 2005, 10:00 PM   #97
VT67 is offline VT67  Belgium
VT67's Avatar
O.K. guys, to make it even harder here's another compact regulated power supply.
Welborne-Labs PS10
Old 11th December 2005, 10:02 PM   #98
bordins is offline bordins  Thailand
Some claim that alot of iron sounds best while others say regulated is best. Supplies definately do affect how a unit sounds to some degree but in the end its still a matter of taste.
It always comes to a subjective conclusion in the audiophile world.
I don't experience that forwordness that you experienced with your borrowed 12B4. .... what I've experienced is massively more detail much better imaging and a wider deeper sound stage over my Grounded Grid line stage.
I had similar experiences at first when I auditioned a 12B4 preamp. But when I took it to my friend's place where 3-4 experienced audiophile arrived on different times, they all said the same thing, without knowing others' comment.
They commented that my "first sighted love" because my ears got attracted by so revealing sonics. But if I listen to it for a long period of time, it might introduce hearing stress.
Originally posted by kooltubes
I have experienced the same thing before and I came to the conclusion that the sound is affected by the operating point and the PSU!
I agree that the PSU is the key. I'll have some tweaks on it.
If you listen it for relaxation, soundstage shouldn't be any concern. 12B4 is so marverlous! But for serious audiophiles, there is still a long journey to go.
Old 12th December 2005, 12:52 AM   #99
frugal-phile(tm)
planet10's Avatar
SS makes me quesy... nice to have the boards.
dave
Old 12th December 2005, 12:55 AM   #100
frugal-phile(tm)
planet10's Avatar
Morgan Jones Valve Amplifiers and RHD 4 which can be downloaded from Geek's website http://geek.scorpiorising.ca/RDH4.html
dave
A copy of the RCA tube manual should be on the list too....
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid.....Hide this!Advertise here!
