Where are the 307A / VT225 amps? - Page 5 - diyAudio
Old 8th January 2009, 06:29 PM   #41
wicked1 is offline wicked1  United States
wicked1's Avatar
I'm a little confused about how to find the optimum current to run these tubes. The voltages we're running them at is off the charts (350 - 400v.. chart only goes to ~340). Is the idea to keep the same ratio, as if the line were on the chart?
My power transformer is supposed to be 350-0-350, but I'm getting over 400v at the tubes. I currently have the bias set to about 58ma. I'm not really using my amp right now because of the high voltage, but I plan to fix it this weekend.
I'm going to try getting my voltage down to 350. At that point I guess I'll try 65ma, like Mr TubeLab.
All of this is way off the charts, and I'm only doing it based on the couple of posts specifying this sort of info here on the forums.
So, just to double check... does that sound about right, or should I shoot for some other values while I'm working on the amp.
This is in a 300b s.e. being converted to 307a
thanks a lot!
Old 8th January 2009, 06:57 PM   #42
dsavitsk's Avatar
Maybe someone has a better take on this, but to my eye, triode connected these look like neither 2A3's nor 300B's so much as 6L6's. Triode connected at least, Rp is slightly lower than a 6L6 (1K5 v 1K7) as is plate dissipation (15W v 19W), though the indication seems to be that pushing these a little is fine.
Conservatively, I think my starting point would be 310V on the plate, -30V on the grid, and ~45mA. Even pushing it to higher dissipation, that -30V on the grid seems about right to me.
Old 8th January 2009, 07:00 PM   #43
coresta is offline coresta  France
coresta's Avatar
Mine are 330 / 335v on plate and G2 according to the WE datasheet , and idle current 48mA (i.e. 33v bias on G1 )
Old 8th January 2009, 08:43 PM   #44
pmillett's Avatar
dsavitsk, you're right, the curves are pretty close to a triode-connected 6L6...
I've been running B+ of 400V and a shared cathode bias resistor of 500 ohms in push-pull... somewhere around 40-45V on the cathodes, I think, so between 40 and 45mA and ~360V across the tubes. So far they seem happy there.
Pete
Old 8th January 2009, 08:57 PM   #45
dsavitsk's Avatar
Pete,
Any suggestions on output transformers? I see you are using a 20W 8K primary. There are lots of 15W 8K's out there, and a few 15W or 25W 10K's. Any sense on optimal load?
I have a pair of 5K 40W (LL1663) that I think I might breadboard with, but this seems sub-optimal to me.
Old 9th January 2009, 12:19 AM   #46
pmillett's Avatar
Originally posted by dsavitsk
Pete,
I haven't tried anything higher than 8k in P-P (I don't have any 10k's)... but less than 8K P-P probably isn't as good. In SE I found 5k is better than 3.5k, so I would guess that 10k P-P would work well.
The most power I've been able to squeeze out of a P-P pair is around 12W @ 5% THD, so I think you'd be OK with a 15W transformer.
Pete
Old 31st January 2010, 05:01 PM   #47
Small 307A amplifier with 5K output trannies from old radio receiver:
307a Single End Amplifier
Dragan
Old 23rd April 2010, 12:14 AM   #48
Pyre is offline Pyre  Canada
Pyre's Avatar
Send a message via MSN to Pyre
Dragan
Do you have a schematic? I got a couple RK-75's that I want to try out SE
Old 7th November 2011, 05:50 PM   #49
jrenkin is offline jrenkin  United States
I resurrected this thread to see if George or any one else had more insight into the 307A. I am thinking of subbing into a 300B tublab SE. Seems like George just swapped them in, meaning B+ of 400V and bias 60mA or so I suppose. Seems hot for these tubes by the WE data sheets.
Old 7th November 2011, 09:41 PM   #50
Tubelab_com's Avatar
They are pentodes with a 5 pin base. I made a crude adapter wired them into my TSE, set the bias to about 60 ma and let it rip. That was more than 2 years ago and it is still running. It doesn't see a lot of use because it was never built into a proper cabinet, but it sounds good. I am not running them at 400 volts though. My TSE has 300-0-300 power transformer. It is a Hammond so it is really a 325-0-325 and the B+ is about 350 to 360 volts depending on the whip of the local power company at any given moment.
The WE spec seems rather conservative at 15 watts plate dissipation and I ran them at 30 watts for a few days, but they sound about the same at 20 to 25 watts.
On a slightly different note another poster in this thread that might be named Pete made this big red board for use with sweep tubes. I got tired of playing with sweep tubes so I stuck some 307A's in the red board. It works, makes about 30 WPC without melting anything. Sounds good too. I haven't had time to play with it in a few months, but I will get back to it.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 11:46 AM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
Copyright 1999-2017 diyAudio
