diyAudio Sponsor
Old 19th November 2005, 01:18 PM   #1
Default Poinz 6AQ5 Linestage
OK you experts, can I substitue the 2.2uF 1200VDC Mundorf SS cap with either (2) 4.7uf 630VDC in series or will it hurt to drop down to 2.2uF 1000VDC. I just can bring myself to spend $43 a pop for the Mundorfs.
Old 19th November 2005, 01:31 PM   #2
moamps is offline moamps  Croatia
Default Re: Poinz 6AQ5 Linestage
Originally posted by dstockwell
...can I substitue the 2.2uF 1200VDC Mundorf SS cap with either (2) 4.7uf 630VDC in series or will it hurt to drop down to 2.2uF 1000VDC..
One 4u7/630V will be just fine.
(I'm not an expert.)
Milan
Old 19th November 2005, 01:34 PM   #3
Do you not need two 4u7 in series since the circuit calls for 2.2
Old 19th November 2005, 01:52 PM   #4
It's only a coupling capacitor, so 4.7uF will be better than 2.2uF, giving better low frequency performance (although it's probably too low to make any difference).
Nigel Goodwin
Old 19th November 2005, 02:03 PM   #5
kmtang is offline kmtang  Canada
kmtang's Avatar
You only need 2.2uF 250V for this coupling circuit. 400V is more than sufficient.
I would get the Mundorf Silver in Oil cap for this which will give your detailed sound.
Johnny
Old 19th November 2005, 09:29 PM   #6
Mundorf Supreme Silver oil, are the ones at $43 a pop, and the regular supremes are 1/2 that. $85 for two caps, I would rather go with the regular supremes at 1/2 that.
Socket for 6AQ5 Stuey Tubes / Valves 28 22nd January 2009 08:39 PM
Help with 6AQ5 schematics kacernator Tubes / Valves 5 17th January 2008 11:46 AM
Driving 6AQ5's jerluwoo Tubes / Valves 10 22nd June 2007 05:08 PM
6aq5.......6v6....... diesel_tech Tubes / Valves 9 23rd February 2007 12:43 AM
Which 6AQ5 dstockwell Tubes / Valves 4 12th December 2005 11:05 AM
Page generated in 0.08717 seconds (75.65% PHP - 24.35% MySQL) with 11 queries
