diyAudio Sponsor
Old 19th November 2005, 02:37 AM   #1
Bryan is offline Bryan  United States
Default Humm in my preamp...
Hey All,
So, I have rebuilt my preamp (seen in 12B4A Linestage thread) in new enclosures and I now have some hefty hummmmmmm.
I've looked over my grounding scheme, and it looks fine. I think the problem may exist from the PS chassis, and the chokes being places too near each other.
So, time to ask the experts...
First things first. When I look at the ripple, I measure 5.0 and 4.1 mV on the L and R channel output. I can trace this back to the plate. What is more interesting is the ripple at the last filter cap before the ccs which loads the plate. It dances around at values between 8 and 14 mV, and is not steady. After the CCS, it is staedy at the 5.0 and 4.1 mV values.
Any thoughts?
Dont take life too seriously, you will never get out alive!
Old 19th November 2005, 02:57 AM   #2
Geek's Avatar
Sounds to me like it may be 1) poor chassis layout or 2) induction throught he cassis.
Did you use steel or aluminum?
Old 19th November 2005, 03:43 AM   #3
Aluminum.
To clarify (or complicate matters) there are two chassis. PS and Audio. Both are built on aluminum top plates which sit on wood chassis. Both top plates are grounded.
Interesting enough, I just pulled the regulator tubes (thus eliminating B+ from the valves) and I still have the hummmm. Would this lead one to believe the humm is coming from the heater circuit? I'll poke around there and see if I can uncover anything....
Old 19th November 2005, 08:30 AM   #4
Shoog's Avatar
AC heaters are very unlikely to induce that much hum. Almost all valves cope very well with AC heaters.
Its much more likely to be induced hum from poor layout. My last Valve headphone amp had real issues with hum, which all turned out to be induced and ground loops. I just completed a valve phone amp and absolutely no hum first time.
Its really a matter of search the net for guidance on eliminating earth loop hums and trying everything systamatically one at a time.
Shoog
Old 19th November 2005, 11:31 AM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Originally posted by Bryan
snip..
Interesting enough, I just pulled the regulator tubes (thus eliminating B+ from the valves) and I still have the hummmm. ..snip...
Aren't your regulators shunt? If they are, pulling them doesn't remove B+...
Old 19th November 2005, 01:08 PM   #6
This is in fact true. I realized this error last evening after I typed the reply, but could not find the "edit" tab on the webpage...
I'm going to tweak with the wiring layouts and tripple check my grounding. It must be something simple that I am overlooking.
I'll report back my findings after I finish poking around.
Thanks,
Bryan
What's causing that #$%&@$ humm?? sachi Chip Amps 10 9th February 2006 01:29 PM
System humm Flemming J P Everything Else 3 2nd December 2003 07:52 PM
Humm...first post :) Sch3mat1c Car Audio 3 26th February 2003 09:10 AM
Humm whatgive Tubes / Valves 4 8th February 2003 04:24 AM
humm in sds headphone amp. rwagter Headphone Systems 4 19th August 2002 04:13 PM
Page generated in 0.09734 seconds (78.54% PHP - 21.46% MySQL) with 10 queries
