diyAudio Sponsor
Old 17th November 2005, 11:37 AM   #1
Default How did you do your Aikido?
Ok, another Aikido thread if no one minds.
I purchased (2) power supply boards so I could put together 2 separately powered Aikido channels for the total experience.
I was lucky enough to have salvaged (2) transformers from 2 commercial 6V6 SE paging amplifiers for my power transformers.
My transformers were 275-0-275 with plenty of spunk on the high voltage side but somewhat lacking in the current department when lighting the 6.3 volt filament. That was my reasoning for using two transformers instead of one.
I tried the 6N1P for the 1st tube and the 5687 for the second tube
and found the sonic signature to be great.
My second ecperience was to try a 6FQ7 in the #1 tube spot with a 5687 in the second spot.
I am enjoying the 6FQ7 better than the 6N1P. Seems more open, free and uncluttered. This may or may not account for the higher price on ebay for this tube.
Still sitting on the counter in the garage without an enclosure at this time.
What is the status of your diy Aikdio project?
Old 18th November 2005, 01:17 AM   #2
Bill*B is offline Bill*B  United States
Built mine with octal 12AH7 in both positions, but biased with a 2K2 on the input and a 1K on the output (330V B+). A bit of an odd one in that I transformer coupled both input and output. Once I got the output transformer grounding sorted out, it has been a well behaved performer. Bill.
Old 21st November 2005, 10:15 PM   #3
Here's a link to my "Aikido" (and power supply) details/photos for those who may be interested. "Aikido"
Old 21st November 2005, 10:22 PM   #4
Very nice Bill.
Old 22nd November 2005, 04:44 PM   #5
aletheian's Avatar
i built up an Aikido with a 6SJ7 into to a 6922. The gain is pretty high, but the noise is really low. The pentode was hand picked for low noise and microphonics. I used a pretty stiff 350V-ish mosfet-regulated chokeless supply. The sound is sweet, with some pentode roundness. I'm diggin' it.
Heghlu'meH QaQ jajvam!
Old 22nd November 2005, 04:55 PM   #6
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Could you post the schematic? I have an Aikido with 6dj8 and ecc81, but i want more gain and i would like to use a 6EJ7 i have at hand.
Old 22nd November 2005, 05:16 PM   #7
aletheian's Avatar
Here is the schem without the component values since you would have to tweak them for your tube anyway.
I think I ran the 6922 with either 390r 0r 470r cathode resistors (don't remember which I settled on) and a 500K trimmer as the R9, wired as a variable resistor... a 470K-ish setting produced the lowest noise. I ran the grid stopper before the grid to ground at the input to ditch a little input signal at first, but I have moved it to the other side since then. The C3 snubber is probably not neccessary, but I usually have one there to tweak the brittle high end of my crap DAC. I had a variable B+ supply, and ran it between 290v and 350v, and finally settled somewhere in the middle, but it sounded pretty good over most of that range.
Old 22nd November 2005, 09:20 PM   #8
Cassiel's Avatar
Thanks.
Old 22nd November 2005, 11:24 PM   #9
Used 6N1P, now using 6FQ7/6CG7 into 5687's without changing any operating points. Sounds good either way.
Mr. Aikido working in the dark, as usual.
The setup,Click the image to open in full size.
the little gold box is a 12AU7 cathode follower to drive the Crown DC150 to Subwoofer. Sony 685 modded with tube output stage, my Aikido drives 2 EL84 based monoblocks to Alk's modded Klipschorns.
dr._sleep
Old 23rd November 2005, 04:45 AM   #10
Lord, I've always wanted a pair of Klipschorns. I'll bet that setup sounds great.
Use 9 pin Aikido PCB kit or buy 8 pin ? Renron Tubes / Valves 6 25th November 2007 04:52 PM
JB Aikido Pre 9 pin kit Renron Swap Meet 1 20th November 2007 07:51 PM
New PSU for Aikido? cbutterworth Tubes / Valves 5 6th September 2007 01:03 AM
Aikido HiFiNutNut Swap Meet 1 24th January 2007 04:26 AM
Aikido PSU help cbutterworth Tubes / Valves 48 13th October 2006 07:54 PM
Page generated in 0.13858 seconds (69.52% PHP - 30.48% MySQL) with 11 queries
