How did you do your Aikido?
Ok, another Aikido thread if no one minds.
I purchased (2) power supply boards so I could put together 2 separately powered Aikido channels for the total experience.
I was lucky enough to have salvaged (2) transformers from 2 commercial 6V6 SE paging amplifiers for my power transformers.
My transformers were 275-0-275 with plenty of spunk on the high voltage side but somewhat lacking in the current department when lighting the 6.3 volt filament. That was my reasoning for using two transformers instead of one.
I tried the 6N1P for the 1st tube and the 5687 for the second tube
and found the sonic signature to be great.
My second ecperience was to try a 6FQ7 in the #1 tube spot with a 5687 in the second spot.
I am enjoying the 6FQ7 better than the 6N1P. Seems more open, free and uncluttered. This may or may not account for the higher price on ebay for this tube.
Still sitting on the counter in the garage without an enclosure at this time.
What is the status of your diy Aikdio project?
stalker said:
Could you post the schematic? I have an Aikido with 6dj8 and ecc81, but i want more gain and i would like to use a 6EJ7 i have at hand.
Here is the schem without the component values since you would have to tweak them for your tube anyway.
I think I ran the 6922 with either 390r 0r 470r cathode resistors (don't remember which I settled on) and a 500K trimmer as the R9, wired as a variable resistor... a 470K-ish setting produced the lowest noise. I ran the grid stopper before the grid to ground at the input to ditch a little input signal at first, but I have moved it to the other side since then. The C3 snubber is probably not neccessary, but I usually have one there to tweak the brittle high end of my crap DAC. I had a variable B+ supply, and ran it between 290v and 350v, and finally settled somewhere in the middle, but it sounded pretty good over most of that range.
Used 6N1P, now using 6FQ7/6CG7 into 5687's without changing any operating points. Sounds good either way.
Mr. Aikido working in the dark, as usual.
The setup,
the little gold box is a 12AU7 cathode follower to drive the Crown DC150 to Subwoofer. Sony 685 modded with tube output stage, my Aikido drives 2 EL84 based monoblocks to Alk's modded Klipschorns.
dr._sleep
burnedfingers said:
aletheian
Would you mind posting your B+ and resistor values? I realize values may need to change but your circuit looks very interesting.
Thanks,
Joe
I'll post what I can remember, but I tried a lot of changes, and don't remember which I likes best. I tried higher gain version, with a 220K plate resistor on the pentode, biased a bit cooler (2mA), and also a lower gain and triode strapped version with much more current (10mA). So I'll just post what I remember. ALSO, I used values of resistors for the tester circuits that I has lots of, so they are probably not exactly optimal.
burnedfingers said:
aletheian
How quiet is your 6SJ7 Aikido?
Dead silent running from my system into my hard wired gainclone monoblock. I am very impressed with the the Brooksie design. It is so quiet that when I first powered it up, I thought something was wrong, but I cranked it up , ungrounded the input and touched the hot contact of the input jack with my finger... well I was greeted by a mighty "BZZZZZTTT" through the speakers that nearly gave me a heart attack.
But like I mentioned before, it has a definate Pentode character, but I had a few NOS RCA 'hand selected for first stage' 6SJ7's lying around ,and some nice 6922's, so I figured I'd just give it a try. Some 6SJ7's tend to be noisy though. I am thinking of trying a 6AU6 as well, since I have a couple of those.
