Hey people, I'm looking at building something along the lines of this 807 PP amp. It's basically a re-worked Williamson design (UL), which has taken into account a few of the critiques that have been written of that design over the years. More info on it here
Obviously it's not my design and I am much more highly skilled in the construction than in the real expert understanding of such things, though I view this as a way to learn and experiment. Does anyone have any comments, critique of the design etc? I have the chance to get custom made trannies for it, made by a retired transformer winder who remembers when valve technology was all there was, he still does jobs for friends. My impression is that the amp has been designed around available iron, rather than the other way, is there a way to work out exactly what OT specs would suit the amp? I'm thinking impedance here and any other specifiable characteristics, I'll leave the choice of how to actually achieve those things to him. Thoughts? |
#2 | ||
Hi TheVoice,
I suggest to consult the 807 UL OP curves available somewhere on the net. Donīt remember the URL right now, but it may have been at the Sofia / Automatica curve tracer homepage. Tom
If in doubt, just measure. |
#3 |
Ah, I found the curves again:
807 tetrode, UL and triode plate plate curves Lots of other interesting plate curves at that, too. Tom
#4 |
Cheers Tom, I spoke to you briefly on email a little while ago about the PS for this.
Thanks for the link, now I have to work out how to use the curves properly, like I said I deal much better with the physical construction than understanding the electronics. I've got some reading to do. |
#5 |
"Does anyone have any comments, critique of the design etc?"
Yes. I'm not a real big fan of the Williamson topology. It seems absurd to use a cathodyne to split the phase, and then use a LTP to further amplify the two signals. The LTP could do both jobs at once. But that's just me. Preferences aside, there are only three problems that I see. First off (see attached) the tail on the differential amp is too short. You might get away with that with a solid state LTP, however, 6SN7's don't have the gain that transistors do. That thing needs a CCS instead. Secondly, I don't see any provisions for adjusting either AC or DC balance. Finally, the 807s are missing the plate suppress resistors. The 807 Application Report calls for 100 ohm plate stoppers if operating class AB1 (like here) or 47 ohm stoppers for Class AB2. (Adding a 10 turn coil across the resistors wouldn't hurt either.) After all, the 807 is an RF power amp tube. |
#6 |
To give you an idea of whats happening in the tail of the diff. amp... The Tail R is 1.2K ohms.....Now looking into the cathode of each 6SN7 you will have roughly 3.1K ohms.... at that operating point...
Idealy you want this tail to be infinite in a perfect world.... Since you get a current divider affect ...you want all the AC current to couple.... SO you can do the math and see whats acceptable in terms of coupling co-efficent and then determine what value you need in the tail to accomplish this.... On the other hand, the coupling was known to be poor...that why they used a balance pot to adjust the AC signal balance.... Also, some amps use feedback technique in the tail...this method known as "bootstrapping" is used to make a small Tail R look effectively like a larger impedance to AC signal.... this feedback method also self balances itself and the output stage when properly implemented..... Chris |
#7 |
All you ever wanted (almost) to know about using the 807
The definitive 807 Users Guide. http://www.retrovox.com.au/STC807.pdf Cheers, Ian |
#8 | |
Jason |
#9 | ||||
Hi Miles,
If one goes for class AB instead (which conceptually would be a completely other amp, able to crank out at least 30-40 watts and fixed bias should be used), plate stoppers probably would be helpful, indeed. Quote:
![]() Tom
#10 | |
Hi Jason,
Tom
| PP amp design , your thoughts please. | Nihilist | Tubes / Valves | 40 | 8th June 2009 06:33 PM |
| Thoughts on my design? | NogginBoink | Subwoofers | 6 | 24th July 2005 08:14 AM |
| First GC design. Any thoughts? | DC Dave | Chip Amps | 7 | 5th February 2004 04:26 AM |
| Thoughts on My Speaker Design | Street | Multi-Way | 16 | 25th July 2003 07:29 AM |
