diyAudio Sponsor
Old 17th November 2005, 05:08 AM   #1
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default tube amp for biamped speaker
I am building a speaker using 2 18cm 8 ohm woofers (push push) and a 1" dome tweeter (6 ohms). Scan Speak 18W and 9900. I have never built a tube amp but have heard a few.
I intend to biamp them with tubes. the idea being to use the preamp-2nd order 2.5khz crossover-power amp in one box to improve WAF.
There will be 3 souces for this system (CD, Ipod, and Cable TV audio).
I am looking at about 10W for the tweeter and about 50W for the woofers. I am not comfortable with very high DC voltages.
my concept is to use Class A Push Pull EL84 for the tweeter and Class A Push Pull EL 34 for the woofer but the EL34 would only produce 20W in class A and would have to baised to Class AB for 40W. Any other tubes that canbe used with lower DC voltages?
I also hope that each amp (Low Pass and High Pass) would have only 1 driver tube to reduce tube count.
BTW I favour push pull so that the output trannies are smaller.
Since all my soruces are High signal sources (300mV+) I hope to get by using just a single 3 way 2 pole selector and a single tube for volume control. Any ideas on this?
Anyone have a circuit for a 12db 2 way tube crossover? How many tubes will this need.
another alternate is to get a 3 box design with one box being the input selector, volume control and crossover and 2 boxes each having a 10W and 50W tube amp next to each speaker.
...still looking for the holy grail.
Old 17th November 2005, 01:05 PM   #2
Sherman is offline Sherman  United States
Default Re: tube amp for biamped speaker
...only 1 driver tube to reduce tube count.
...another alternate is to get a 3 box design with one box being the input selector, volume control and crossover and 2 boxes each having a 10W and 50W tube amp next to each speaker.
One should never overestimate the WAF of a tube amp design. It is often (usually, almost always) much less than we think it should be! It sounds like you have a handle on what might be required in that department.
Your idea for a source switch is fine, I typically use a two-pole/four position rotary switch (non-shorting or break-before-make) as a source selector.
As for getting everything in one box... I suppose it could be done but I would recommend your three box design. For a preamp, high-end amp and low end amp you are likely to need three power transformers. You will of course also need four output transformers. Easier to put the preamp and crossover in one box and your power amps in separate boxes.
A couple of question though about the power requirements. How efficient are your speakers going to be, how large is your listening room and how loud to you like to listen? The reason I ask is that with 89bB/W/M speakers a couple watts for the tweeters and a dozen or so watts for the low end would be awfully loud in a small to medium sized room.
--Sherman
Old 17th November 2005, 08:46 PM   #3
Hi
You could also build the crossover's into the power amp, just choose a right RC combination: put one in front of the driver stage and one between driver and output stage (assuming a two stage design, which I believe should be sufficient for a PP EL84 and/or EL34.) Another option is to build the crossover from steve bench which uses an ECC88, one per channel. This approach attains it advantages too, because you keep the crossover thing apart from the power amp thing. As for the power - you can go the traditional way connecting tubes in parallel for double power: you will double current from the PS and an output tranny with half the impedance.
Steve Bench's crossover
http://members.aol.com/sbench101/#Electronic
Erik
Old 18th November 2005, 02:37 AM   #4
For the woofer amp, consider KT88s running "hot and low". You'll get about 40 W. from a PP pair set up in Class "A" pentode mode. If you can tolerate Class "B" operation when peak power is produced, the 50 W. target is in sight. Max. linearity in pentode mode requires regulated screen grid B+.
Only 2 stages looks like differential splitter/drivers to me. That's good for the loop NFB pentode mode needs. Big question, can a 12AT7 provide enough gain for the woofer amp's needs?
Marchand 24 dB./octave crossovers use 4 twin triodes per channel. A 12 dB/octave crossover would use 1 less "bottle" in each channel.
Eli D.
Old 18th November 2005, 09:19 AM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
10W for the tweeter and 50W for the bass? Is the tweeter really 7dB more sensitive than the bass drivers? It's common to find tweeters that are 3dB more sensitive, allowing 10W and 20W...
I second the suggestion of using Steve Bench's crossover.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th November 2005, 10:43 AM   #6
navin's Avatar
Default Re: Re: tube amp for biamped speaker
the tweeter is the ScanSpeak 2905-9900 the woofers are 18W8546 in push push. approximate sensitivity about 88-90db for each.
my idea was to build the power amps into the base of each speaker cabinet and only keep the preamp-crossover visible. this will mean that the pcrossover-power amp wire will be about 16 ft (5m). can a tube drive such a long length of cable?
thi sis why I was was looking at builiding 2 power amps (EL84/EL34 for example) into one box. It will mean two more transformers but the cost of tehse will be offset by the fact that the power amps will be hidden. besides the transformers will be very good ballasts for the speakers. :-)
Originally posted by ErikdeBest
You could also build the crossover's into the power amp, just choose a right RC combination...Another option is to build the crossover from steve bench which uses an ECC88, one per channel. This approach attains it advantages too, because you keep the crossover thing apart from the power amp thing. As for the power - you can go the traditional way connecting tubes in parallel for double power: you will double current from the PS and an output tranny with half the impedance.
Erik
thanks for the link it looks nice. now should the crossover be inside the power amp or inside the preamp?
I would look at parallel tubes but i am told that keeping 4 tubes (Parallel Push Pull) biased similarly is not easy. hence i was looking at a singple pair per channel.
Originally posted by EC8010
10W for the tweeter and 50W for the bass? Is the tweeter really 7dB more sensitive than the bass drivers? It's common to find tweeters that are 3dB more sensitive, allowing 10W and 20W....
the woofer and tweeter have the same sensitvity. but at 2.5K (my exected crossover freq). the energy at the woofer will be 5 times that of the tweeter hence the woofer amp will need to about 5 times the tweeter amp.
thanks guys for all the help. sure would love more!
still a bit confused.
Old 18th November 2005, 10:49 AM   #7
EC8010's Avatar
Default Re: Re: Re: tube amp for biamped speaker
The woofer and tweeter have the same sensitvity. but at 2.5K (my exected crossover freq). the energy at the woofer will be 5 times that of the tweeter hence the woofer amp will need to about 5 times the tweeter amp.
If you think about it, the energy in music at 2.4kHz (just below your crossover) is unlikely to be significantly different to that at 2.6kHz (just above). In which case, given that the tweeter is the same sensitivity as the woofers, each amplifier must deliver the same power.
What sort of music requires 5 times the power in the bass compared to the treble?
Old 18th November 2005, 11:40 AM   #8
I don't know what kind of preamp you have in mind, but because you're using sources with a high output you probably won't need any gain. And then there are the cables - long cables require a low Z-out source. No gain (well, actually something around 0,95) and low Z-out are the main characteristics of a cathode follower, the configuration used for the ECC88 in the crossover. So (in my opinion) you can use the ECC88 for both crossover and preamp buffer. Note you have to run two signals cables to each speaker (you can use balanced cable with common ground, but I think this won't be good because of crosstalk issues - has been discussed in some thread...)
As for the power you need - have you had a look at this article?
http://www.tubecad.com/articles_2001...ers/index.html
Erik
. If you decide you don't need gain in the preamp you can use the ECC88 crossover as pre-amp
to go this way you can use the crossover as
This way you can use the
Old 18th November 2005, 01:13 PM   #9
navin's Avatar
Default Re: Re: Re: Re: tube amp for biamped speaker
I was given to understand that music has about half it's energy under 300Hz and the other half above 300Hz.
I don't know what kind of preamp you have in mind, but because you're using sources with a high output you probably won't need any gain. ...you can use the ECC88 for both crossover and preamp buffer. ...As for the power you need - have you had a look at this article?
thanks for the link, I might not need gain but i will need a volume control so the preamp was only for the volume control and to drive the long cables to the power amps.
Old 18th November 2005, 01:51 PM   #10
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Well for the bass amp you could use a pair of 6c33's (6s33s)
The tweeter amp could use it's samller brother, the 6c41c(6s41s)
These are low voltage Russian types, both extensively used in single ended designs, but there is no reason not to use them in PP.
Having very low Rp makes transformer design easier.
DC offset affect on biamped speakers daly2k Pass Labs 3 3rd July 2006 06:59 PM
Biamped System with LM4780s kent Chip Amps 1 27th June 2006 11:43 AM
Biamped Open baffle/Sealed Comments pls kestrel200 Multi-Way 4 23rd January 2005 02:33 PM
Grounding in a biamped buffered system Raka Chip Amps 20 19th November 2003 12:49 PM
Wattage required for biamped ESL phishead8 Planars & Exotics 6 3rd July 2002 12:42 PM
Page generated in 0.23702 seconds (56.09% PHP - 43.91% MySQL) with 11 queries
