diyAudio Sponsor
Old 16th November 2005, 02:19 PM   #1
Send a message via AIM to mrhotmark
Default HAMMOND 125ESE Transformer WIRING
I am updating an older Fender Champ amp. For the Hammond 125ese output transformer, it's obvious that on the secondary the black wire is ground and the other wires select the primary impedance as seen by the power tube. I plan on using negative feedback from the speaker to the cathode on one of the 12AX7's. The 125ESE primary wires are blue and brown. The question is which wire goes to B+ and which wire goes to the ouput tube plate for proper wiring?
Old 16th November 2005, 06:19 PM   #2
Gilbert is offline Gilbert  United States
According to the Hammond web site, brown to B+, blue to tube
Old 24th March 2010, 09:30 PM   #3
Default Old Post Saves The Day!!!!!
I know this post is very old but the info you supplied is very new to me and very needed. I am about to install a Hammond 125ese in my Blackheart LG and needed this invaluable info,thanks.
SimpleSE OP Hammond bigger than the 125ESE Mungo Park Tubes / Valves 4 1st May 2009 06:27 PM
FS: Hammond 125ESE trannies RockysDad Swap Meet 0 26th November 2008 03:20 AM
Hammond 125ESE and sections mpingo Tubes / Valves 0 10th January 2008 06:41 PM
Help with wiring a Hammond Power Transformer wonsup Tubes / Valves 3 7th January 2008 01:07 PM
Cheap Source for Hammond 125ESE Technotinker Tubes / Valves 4 1st February 2006 12:01 PM
Page generated in 0.16480 seconds (35.05% PHP - 64.95% MySQL) with 10 queries
