| diyAudio Sponsor | ||
Greetings,
I've run into a problem building the 12v filament supply in the attached drawing. I couldn't find 15v trans. so I got a couple of 14v hammonds. The problem is the reg. drops the voltage from 14 to about 10.6v. How do I bump the voltage up to 12.6v. Thanks Brian |
#2 |
Try a low-drop-out regulator IC instead of the standard 7812. LM2940 family is one of the examples for the low-drop ICs.
Good luck! |
#3 |
Can you check the DC voltage at the input of the 7812 regulator IC? I believe it should be somewhere around 18Vdc. It should provide sufficient volt for the 7812. If the transformer is with CT configuration, you may use 2 diodes for the full wave rectification. This will lower the volt drop across the rectifier circuit.
The total filament current draw should be 0.475A that the 7812 should able to handle. Johnny |
#4 |
The 7812 regulator needs at least 14 volts input to work. With the diode in the ground leg it will want 15. Check the voltage at the input to the regulator, if it is slightly low you can pick up an additional .5 to .8 volts by switching to Schottky rectifiers, they have a lower voltage drop, and are usually quieter.
If that doesn't provide enough voltage, use a low dropout voltage regulator instead of the 7812. The previously mentioned National Semiconductor part is a good option. I use the LM2941, adjustable regulator, but it has 5 pins which makes hand wiring dificult
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#5 |
The voltage before the regulator is about 14.6. After it drops to 10.6.
I tried removing the regulator altogether and added a 8ohm resistor and that gave me 12.6 exactly but I am worried that I'm deviating too far from the original design and I'll suffer noise on the phono and line stage. I tried a couple of 1n4004's to the ground leg but that only raised a few tenths of volts. I'll look for LM294X at mouser. Brian |
#6 |
The 8 ohm resistor is not a bad idea, especially if a reasonably large capacitor is added to ground after the resistor. A resistor in series with the tube heaters limits the inrush current, and promotes longer filament life. I would leave it there, and finish the preamp. Then you can listen for noise.
#7 | |
If the voltage is 14.6 volts going into the regulator, it's possible that the 10,000uf capacitor is open or is not connected properly. Check this capacitor. If your transformer is indeed delivering 14 volts into the full wave bridge and the input capacitor is doing its job, you should see a little over 18 volts at the input of the regulator.
Frank |
#8 |
Although well covered here in other posts, at least 5 volts higher than needed on the input side should be used. Line voltages can dip some during different times of the day.
Too large of an input cap will actually produce lower voltage as the transformer can not recover from the repetative peak surge current . I see this condition clearly on a power supply simulator program. I would just purchase another transformer at 18 volts output and heatsink the regulators. I consider 15 volts AC marginal with a lower current transformer. Obviously, it is. |
#9 |
Are your Hammond transformers capable of delivering enough current? As tubelab.com asked, when the output voltage of the regulator dips to 10.6 volts, what is the input voltage to the regulator?
I would not use a transformer that produces 18 volts. That would put 25.5 volts at the input of the 7812. Too much voltage drop across the little guy when it is delivering .425 amps.
Frank |
#10 |
The trannie is 1a (I'm guessing I'm at work, Ill check in two hours when I get home)
I 'll have a look at my wiring, I have plenty of the 10k caps, I'm thinking they're backwards?? The voltage doesn't appear to change until it gets to regulator so if I'm supposed to have 18v that gives me a couple of things to check. |
| P88 Preamp problem | Curioprop | Solid State | 5 | 17th July 2007 02:01 AM |
| 26 preamp problem | NickC | Tubes / Valves | 7 | 13th February 2006 01:12 PM |
| Need help w/ NAD preamp problem | Jim B | Solid State | 13 | 3rd May 2005 02:41 PM |
| Mic preamp problem | kimarin | Solid State | 1 | 29th October 2004 09:11 PM |
| X2 preamp problem... | audionuts | Pass Labs | 1 | 28th October 2004 02:28 PM |
| Page generated in 0.28192 seconds (39.02% PHP - 60.98% MySQL) with 11 queries |
