| diyAudio Sponsor | ||
Hi everyone,
I need some help with a tube amp I have.It has no make exept for the transformer which is a peerless /altec lancing corp seriel 16277.It has 2 12ax7,one 12au7,one vr150 written in chassis plus two tube sockets.I got it with the following tubes 2 x 12ax7,1 x 12au7,1 x od3,2 x 6l6g.It has a 8 pin plug for the psu.I would like to find the schematics for this but do not know exactly what it is.power amp?preamp?one black rca plug and 4 red pin plugs.screws for impedance unmarked. any help welcome.It has a screw for balance aswell. Thanks |
#2 |
tarmac ripper
Have a look to this link
http://www.triodeel.com/schindex.htm There is quite a number of altec/perleess schematics. Hope you find something useful. It should be a power amp. mono. Ciao Gianluca |
#3 |
thanks for the link.unfortunatly haven´t found what I´m looking for.Cheked again inside the chassis but nothing written there either.
Any more help anyone? Thanks |
#4 |
I think it is pretty obvious looking at it that this amplifier was a DIY effort and not the product of some audio company. Looks nicely built though, too bad you have not got the supply that goes with it. The chassis box appears to be a bud box incidentally. I have seen a lot of home brew amplifiers in this neck of the woods over the years and some of them were built to very high standards.
Kevin |
#6 |
Seems like a tube regulated power supply to me.
Johnny |
#7 |
Johnny |
#8 |
thanks everyone.I´ll post pictures of the inside and more details asap.keep checking.
#9 |
I don't believe it is a power supply, as I recall I used the same type of peerless output transformer in one of my long ago projects. The OD3 could be used for screen regulation if the amplifier is set up for tetrode mode operation. The driver topology is anyone's guess..
Kevin |
#10 |
What is on the other end of the black cable which appears to be coming out of the chassis?
This looks like a monoblock amplifier. At first guess, I'd say that the black cable goes to an external power supply. Please furnish photos of the underside.
Frank |
| Altec 811B horns and Altec 414z 12" Speakers | xecluded | Swap Meet | 0 | 21st September 2008 05:21 AM |
| peerless xxls sealed -vs- peerless xls with passive radiator | Naudio | Subwoofers | 8 | 23rd March 2008 09:00 PM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 01:29 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 04:20 AM |
| Whats the difference between the Peerless 831916 and Peerless 850122 | SkinnyBoy | Multi-Way | 9 | 12th June 2003 03:11 PM |
| Page generated in 0.13335 seconds (59.94% PHP - 40.06% MySQL) with 11 queries |
