Parallel Single-Ended Questions - Page 2 - diyAudio
Old 5th March 2010, 07:48 PM   #11
porkchop61's Avatar
Great! Thanks for that information.
I too want to play around with this type of design for a little more power. What are you using for an OT? I'm currently running my dual monoblock build with Hammond 1628SEA's. I think these will handle two KT88's in parallel as they are rated for 30 watts.
I think adding two more KT88's will put me over the top on my PT though. I'm again using a Hammond 273BX, and it's sized correctly for the tube compliment I'm running right now. Time for a different PT I guess.
I'm still really enjoying the LED bias on the power tubes, best change I've made so far!
Later.
Glenn
"Imagination is more important than knowledge"
Old 5th March 2010, 11:53 PM   #12
Just a comment; to parallell tubes means that you have to halve the OPT primary impedance to get the desired doubling of power. If you have 8 ohm speakers and want to stay with the 1628 you should try to hook them up to the 4 ohm connection. That will give you a reflected 2.5k primary, should be about right for parallell KT88's
/Olof
I'm not allowed to do magic, union rules...
Old 6th March 2010, 03:04 AM   #13
AKSA is offline AKSA  Australia
You could use a higher gain tube, running 10mA or so, and a 2:1 step down interstage, which will give you four times the drive.
One which comes to mind and is a good tube is the 6GK5. Rp is around 5400R, so four to one would give you a Zout around 1K4, plenty to drive a stiff grid bias resistor, too.
Downside is overload margin at the grid, not much more than 3Vpp, but you will have very good overall gain.
Another approach - with no interstage - might be to use Pete Millet's 12HG7 driver with 400V B+. This has a Zout around 4K, and very low distortion with excellent overload margin. BUT, this tube is a pentode, and lots of folks bring out the wooden cross when the word comes up in conversation.....
See attached.
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Mission 300b parallel single ended duderduderini Tubes / Valves 1 17th October 2007 10:21 AM
Single-Ended 6V6 Questions raymond_iii Tubes / Valves 2 24th February 2004 08:54 AM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 07:04 AM
Parallel, single-ended Pentode. How? arnoldc Tubes / Valves 2 16th December 2003 11:35 PM
Copyright 1999-2017 diyAudio
