| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
Thread Tools |
I am interested in buying the Heresy Tube/Mosfet preamplifier for my Autocostruire T-Amp. This is available in three versions, with either ECC82, 6SN7 or 6SL7 tubes.
see - http://www.autocostruire.com/catalog...roducts_id=267 I appreciate that sound quality is very much a personal experience, but what are the individual merits / characteristics of these three tubes and which is considered to be "the best" when it comes to that all important sound quality? Tube size is not an issue. I am using the Autocostruire T-Amp to drive my Quad 63's with excellent results, but I am also interested in hearing "that valve" sound which is so much talked about amonst audiophiles. I listen mainly to FM radio and CD's with a preference for Classical rather than pop. Whilst the Forum "Tube Choice for tubed crossover" has some interesting posts, they do not appear relevant to my situation. Thanks in advance for advice and recommendations - CambshireGordon
Let your ears by your judge |
#2 |
I'd use the 6SN7 - it's the best sound. The 6SL7 is warmer and fuller but less neutral, and probably has too much gain to be really suitable. I question the value at €250 - the parts are pretty basic.
#3 |
I would go with the 6SN7 also. The price seems very high considering the parts count. A diy 6SN7 linestage would surely be better sonically.
#4 |
No brainer here- 6SN7
#5 | |
Tetsujin
Depends on your goals.
From their website: Quote:
"We all feel like that, Reggie, now and then, especially when Spring is upon us, but few of us would care to put it on our cards." — Sir Archibald Clerk-Kerr |
#6 |
GlassFET
How 'bout a 6CG7/6FQ7, best of both worlds
-= Gregg =- Hobby and communites: GeeK ZonE - Commercial site: classicvalve.ca - diyAudio Blog - GeeK's Bench |
#7 |
diyAudio Moderator Emeritus
It seems an odd set of options: 6SN7 and 12AU7 are very similar medium mu, low anode impedance tubes (although, as already stated, the 6SN7 is more linear and sounds better). The 6SL7, however, is quite different, having high mu and high anode impedance. The 6SL7 also can have rather high Miller capacitance, causing roll-off of audible high frequencies, if the impedance of its input circuit is too high. For example, if it is preceded by a volume control pot, the resistance of the pot should not be greater than 250k and preferably 100k or less.
6SN7 would seem to be the best choice here. |
#8 |
Hi ,
Thanks to all for your advice and guidance. Your clear vote is that I should go for the 6SN7. Interesting too that some find the Autocostruire Heresay kit a bit on the expensive side at 250 Euros - (about 168 GBP at Nov '05 exchange rates). I too had that opinion & I believe there is still a power transformer / supply to be factored in! If one of you has experience of this piece of kit, would you let us know, (a new topic heading?) is it value for the money? The (initial) attraction for me is that it is a kit of parts with a printed circuit board too. Here in UK it is not so easy to locate all of the various parts from one source. However, indications are that I could do better (on price and maybe quality components) by building from scratch. Not beyond me providing I have a schematic. Now, where to look for a good 6SN7 design with quality components readily available ... ... There must be a forum here somewhere ... ... javascript:smilie(' ')CambshireGordon
#9 |
Now, where to look for a good 6SN7 design with quality components readily available >>
I can help you if you email me - I'm in London UK. Andy aeatartsandmedia~at~aol~dot~com |
| Thread Tools | |
| 6sn7 and 6sl7 for sale | jeff in WV | Swap Meet | 7 | 5th March 2008 12:36 AM |
| New production 6SL7 and 6SN7 | m1garand | Tubes / Valves | 7 | 27th May 2007 02:54 AM |
| 6SL7 to 6SN7 substitution in power amp? | dmitriy167 | Tubes / Valves | 5 | 23rd June 2006 04:11 PM |
| Recommended 6SN7 and 6SL7 | Miniwatt | Tubes / Valves | 8 | 2nd May 2005 02:23 AM |
| Preamp with 6sn7 & 6sl7 SRPP ??? | Gregouille | Tubes / Valves | 4 | 18th June 2002 10:41 PM |
| Page generated in 0.09039402 seconds (81.69% PHP - 18.31% MySQL) with 10 queries |
