diyAudio Sponsor
Old 12th November 2005, 03:24 PM   #1
kmtang is offline kmtang  Canada
kmtang's Avatar
Default Hammond 156C - good Plate choke load??
I am courious what kind of plate load choke is used in the 5842's driver circuit.
The Hammond 156C is rated 150H at 8mA. Wondering if this is good for this purpose.
Johnny
Old 12th November 2005, 04:42 PM   #2
rdf is offline rdf  Canada
rdf's Avatar
Hi kmtang
My two samples measure a DC resistance just under 3500 ohms and impedance max at 2.1 kHz. From Spice this suggests a parallel capacitance in the 30 pf range, still good for a total choke impedance over 150 kohms at 20 kHz. FWIW I thought they sounded pretty good between a triode-connected E180F biased near 7ma and an 0C3 but were since replaced with IXYS CCSs to try higher currents. They may eventually go back in.
Old 12th November 2005, 05:39 PM   #3
Fuling is offline Fuling  Sweden
I´ve used 156C as plate choke together with 6C4, PCC88 and PC86. Hard to beat for that price
Old 13th November 2005, 03:48 PM   #4
Check out this thread:
Vertical deflection tubes for audio output?
I used them in that amp and they sound great, and they are certainly co$t-effective.
-j
Old 14th November 2005, 02:36 AM   #5
Gary P's Avatar
I'll put in a good comment for the 156C's also. Quite nice sounding, especially for the money!
With the low cost of the chokes you can spring for the big bucks and use 2 in series. This has 3 things going for it.
1st, the inductance is double so you get 1 more octave on the bottom end of the frequency range.
2nd, because the capacitance of the chokes acts as 2 caps in series you will get better high frequency response. In the 26 preamp I built the 3dB down point went from somewhere near 30K to out past 70K. The single choke had a 4dB dip around 40K. With the pair of chokes the dip was only 2dB. There is a broad very low Q resonance around 60K so with 2 chokes in series it drops 2dB down near 30K, then rises back up gently and finally drops below the -3dB point somewhere above 70K. The numbers are vague cause I'm working from memory of a project done several years ago...
3rd, you can mount the chokes on standoffs, bottom to bottom and wire the chokes with one winding backwards. This makes the pair of chokes hum buckers. In my test setup the pair of chokes picked up 20dB less hum than a single choke.
Gary
Old 14th November 2005, 12:41 PM   #6
Joel is offline Joel  United States
Joel's Avatar
Great ideas Gary, thanks.
I used the 156C in my 01A-01A-71A amp several years ago. Much better sounding than a 36k resistor load, as I first configured it.
Joel
Old 14th November 2005, 01:50 PM   #7
kmtang's Avatar
Thank you guys for your valuable information.
Unfortunately, Hammond has the 156C choke only good for plate choke purpose. I am going to experiment using the 5842 tube to drive the 2A3.
The 5842 tube needs almost 20mA. Therefore, I need a plate choke to handle such high current. Any recommendations for a low cost plate choke like the Hammond 156C???
Johnny
Old 14th November 2005, 02:20 PM   #8
I know that Hammond has a 30H / 40mA choke and I think they have a 20H / 20mA too.
Old 14th November 2005, 09:50 PM   #9
rdf's Avatar
Gary
What a great tip! Thx for that keeper.
Old 15th November 2005, 12:43 AM   #10
But that's crazy money - literally DOZENS of dollars! Jeeze louise!
-j
Choke load calculation... HVfanatic Tubes / Valves 9 30th January 2009 02:47 PM
FS: Hammond 1627SEA output transformer + 193H 5H choke marcutan Swap Meet 3 5th May 2008 01:12 AM
PPP KT66, Jensen P15N, Hammond PowTran 378CX/193L Choke Layberinthius Tubes / Valves 13 20th December 2004 01:12 PM
Choke load for CCS-XBOSOZ ??? Magura Pass Labs 6 19th September 2004 08:13 PM
Choke Load or WOT Mas Penk Tubes / Valves 17 13th February 2004 01:57 PM
Page generated in 0.11953 seconds (63.64% PHP - 36.36% MySQL) with 10 queries
