diyAudio Sponsor
Old 10th November 2005, 10:49 AM   #1
nickds1 is offline nickds1  England
nickds1's Avatar
Default RCA 7094 tetrodes...
I have found a pair of RCA 7094 NIB tetrodes in my loft (I bought them years ago as part of a large lot - didn't know they were in there).
I'm a novice in the tube amp stakes - currently just building my first (a nice version of the Bevois Valley amp from Morgan Jones - Sowter transformers arrived yesterday! may be ready for xmas... or maybe not)...
Anyway, do the 7094s have any audio use? Has anyone done anything good with them? As I only have 2, I was wondering if they would make a good SE tube (though I was going to do a 6C33 SE amp next).
Should I just put them on eBay for the radio amateur lot?
Nick
Nicko
"The whole plan hinged upon the natural curiosity of potatoes" - S. Lem
Old 10th November 2005, 01:01 PM   #2
tubelab.com's Avatar
I have never heard of these before, but after looking up the data, they have a set of curves for "Hi Mu triode connection". Here you connect G1 to G2 and use it for the control grid. In this mode it looks like a really pumped up 811A, which makes a good audio amplifier in A2 operation. These tubes would likely do well in a A2 SE amp, but that requires a really good driver circuit. They will also need a lot of plate voltage, maybe 600 to 1000 volts. Since there are no obvious circuits for this, you are forging into uncharted teritory. If you are new to this hobby, I would try a different tube first, at least the 6C33 doesn't need a lot of voltage.
If you decide to put them on Ebay, let us know here. I am crazy enough to try this (as if I don't have enough projects already), but I don't watch Ebay very often.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 15th May 2006, 06:28 AM   #3
Default 7094
Have the same thing. Just finding out what they can do. Any specs on them? Let me know if something develops. Likewise I will do the same.
Russian RF Double Tetrodes ilimzn Tubes / Valves 10 21st January 2008 07:47 PM
Output (beam) pentodes / tetrodes suitable for screen grid drive ilimzn Tubes / Valves 18 2nd September 2005 05:16 AM
Page generated in 0.08245 seconds (64.93% PHP - 35.07% MySQL) with 10 queries
