| diyAudio Sponsor | ||
Hi All.
Picture below is the load line i draw for EL84. I plot it on 250V and 40mA in triode mode. Am I draw it correctly?
Mas Penk |
#2 |
those look like pentode curves to me
#3 |
Yes, You're right it's a pentode load line. But since that's what i got from Data sheet (I used JJ-EL84), that's why i confused to decide the right bias voltage.
Do you know how create a Triode loadline from pentode? thanks and regards
Mas Penk |
#4 |
It's difficult to make a pentode into a triode load line except when you have curves at Vg1=0 and varying Vg2. And even then, you can oly derive the Vg1 = 0 curve. Fortunately, triode curves for the EL84 are easily available. Look at the Mullard data sheet, available at the ubiquitous and invaluable Frank's Electron Tube page.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Sy,
FYI, I believe someone else is currently using the new avatar you have chosen and has been for quite some time. |
#7 |
Hi SY and All,
I found Mullard datasheet... yes there's drawing for triode... I also tried to draw with Plate Voltage 250V Plate Current 40mA at load 5k Ohm. Unfortunately i can't see max voltage since it off scale. the load line is on the red line while green line is max. plate current (65mA). Now, Am I draw it correctly?
Mas Penk |
#8 |
The blue line is the correct load line for the EL84 triode SE with a 5K resistive load. The red line would correspond to a transformer load, assuming an ideal transformer.
#9 |
Thanks for your Info SY...
If i set up circuit to follow the red line, what about the max current limit? I marked green line as Max current limit (65mA). Does it mean that's a bad load line because already reach max current before bias get 0 Volt or I still can use it as long as i don't drive it near max current....? Thank you for your explanation and others opinions are welcome too.... best regards
Mas Penk |
#10 |
I wouldn't worry too much about the max current since your average current will be well below that. You might want to plot max dissipation on those curves to see if your loadline stays below it (on average).
Off the top of my head, 5K and 250V is pretty safe for an EL84- in my little amp, I'm running them with 300V in a push-pull circuit with 8K plate-to-plate. That corresponds to a 2K load single-ended, which is tougher than your load. My tubes seem to be perfectly happy.
| Dynamic load line analysis using music and speaker load | Michael Koster | Tubes / Valves | 0 | 7th March 2008 08:47 PM |
| plotting load-line for OTL amp? | cbutterworth | Tubes / Valves | 2 | 19th December 2007 08:41 PM |
| Load line frustration | eddog | Tubes / Valves | 8 | 20th January 2006 03:29 PM |
| How to design the straight load line for choke loaded tube ? | Antonio Tucci | Tubes / Valves | 14 | 30th March 2005 10:05 AM |
| Load line for CF | mashaffer | Tubes / Valves | 4 | 2nd July 2004 05:13 AM |
| Page generated in 0.15232 seconds (59.95% PHP - 40.05% MySQL) with 11 queries |
