| diyAudio Sponsor | ||
I have a project to assemble the PP amplifier with 6Pi3C-E, pls show me a good schema...
I get units: 4x6Pi3C-E, 2x12AX7, 2x12AU7, 2xPP with UL OPT, 1xPower output 6.3v-10v-350v-370v, 1xChoke 2H 500mA. Thanks |
#2 |
Chao bac Huy, welcome to the forum.
Cu nghi minh la Anh Hung |
#3 |
6P3C is close enough to 6L6G that any schema for one of those should do
#4 |
Hihihi... o xu so nay gap duoc dong huong vui qua! cac bac nha minh suot ngay tranh luan, nen em tam lanh sang day cho do buon ti
Em nho cau "cu nghi minh la Anh Hung" quen lam, nhung hinh nhu sang day bac "thay ten doi ho" nen em nghi mai chua ra Con ai quen o day nua bac gioi thieu cho em biet voi nhe! |
#5 | |
Thanks |
#6 |
HI,
I have built the Annastasia amp from Triodedick website www.triodedick.com Annastasia amp Assastasia power supply I have used 6L6 GC, 6P3S, KT66; it worked fine with any 6L6 type. I have modified the circuit to accomodate a fixed bias instead for convenience, when changing tubes. It's a good sounding amp if you choose carefully your transformers. Alternatively, there are other schematics somewhere on this forum. |
#7 |
Thanks so much.
| push-pull PWM IC | chimi | Power Supplies | 19 | 4th September 2008 09:32 AM |
| An all DHT push pull amp. | Eusebius | Tubes / Valves | 3 | 28th October 2006 12:37 PM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| push pull 845 | audioman | Tubes / Valves | 5 | 30th August 2003 05:53 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
| Page generated in 0.12882 seconds (61.37% PHP - 38.63% MySQL) with 10 queries |
