diyAudio Sponsor
Old 7th November 2005, 10:07 AM   #1
Default help aboutthe 6SN7/5692Linestage
Hello,
I am thinking to built the 6SN7/5692 dual mono linestage to use it with an dual mono kt88PP.
1 - Could you help me to choose between the two design from FDeGrove : what are the difference, advantage/disadvantage one versus the other
Old 7th November 2005, 10:09 AM   #2
Build them and let us know what u think.
Old 7th November 2005, 01:03 PM   #3
kmtang is offline kmtang  Canada
kmtang's Avatar
Personally, I like the 2nd one with coupling capacitor in between the 6sn7. I have built a similar one which sounds pretty good.
Anyway, it is very easy to try both of them.
Johnny
Old 7th November 2005, 01:33 PM   #4
hacknet is offline hacknet  Singapore
i prefer the direct coupled one. its always better to do without those pesky capacitors..!
Old 7th November 2005, 08:39 PM   #5
amperex is offline amperex  United States
I also prefer bottom schematic- direct coupled. Ultrawide bandwidth & no coupling cap to color sonics.
Old 8th November 2005, 06:13 AM   #6
rdf is offline rdf  Canada
rdf's Avatar
Can someone explain the note regarding stepped attenuators? Why would the type of pot determine the biasing scheme?
Old 10th November 2005, 06:46 AM   #7
Sure with some small components more i can try the both, so i think i'll do it
Old 10th November 2005, 09:51 AM   #8
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I expect that what the writer means is that switched attenuators tend to use switches with carefully machined studs and a wiper with quite high contact pressure, so their contact is more reliable than the wiper scraping over the delicate track of a potentiometer. Thus, it is sufficiently unlikely that the contact will be broken that the switch can be safely used as the grid leak resistor, whereas pots are notorious for failing wiper contacts. (Remember that if the grid-leak resistor fails, the triode becomes a diode and current is only limited by the anode load resistor.)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th November 2005, 11:21 AM   #9
porkchop61's Avatar
I built one very similar to this design, and was told that placing a diode between the screen and cathode of the 2nd half of the 6SN7 was adviseable for the tube to survive turn-on (Sy suggested this).
Glenn
FRANK"S 6SN7 preamp/linestage mosfets Tubes / Valves 88 16th February 2012 01:09 AM
Kuei Yang Wang's 6sn7 linestage Yaho Tubes / Valves 4 24th March 2008 07:35 PM
6SN7/5692 for sale-trade grataku Swap Meet 3 30th March 2005 07:01 PM
Current requirements of 6SN7 and 5692 tubes Original Burnedfingers Tubes / Valves 2 28th December 2002 01:07 PM
Page generated in 0.12719 seconds (62.24% PHP - 37.76% MySQL) with 11 queries
