| diyAudio Sponsor | ||
Account Disabled
I got it from internet.
How about conventional of them 12ax7/12au7 and if I want to modify/improve this schematic, How can I do.(I interested Conrad Johnson PV12 schematic but it 12au7/12au7) thanks CFL |
#2 |
First: How much gain do you need? What kind op power amp you are going to drive? What is the lenght of the cables between the preamp and power amp?
From what I see it is a very straightforwarded preamp, with lots of gain (probably way too high for what you need) and a buffered output (for a low output impedance) so you can use it to drive SS and/or long cables. If you need the gain I would go for the Aikido stage, using the ECC83 at the first stage. If you don't need gain I would go with the heretycal line stage from SY. Both designs will probably perform 'better' (that is, on paper) than your schematic. |
#3 |
Account Disabled
I want to build perfectly 12ax7+12au7 such as my uploaded file but I like direct coupling from 12ax7 to 12au7.
Could anybody suggest me how to calculate or compare with brandname schematic. Happy for quick reply CFL |
| looking for a pre-amp schematic | steamPunk | Tubes / Valves | 3 | 3rd August 2008 01:49 PM |
| DBX 500 schematic | d3imlay | Solid State | 0 | 2nd August 2008 05:12 PM |
| F3 schematic | kenev | Pass Labs | 2 | 24th January 2008 03:24 PM |
| Need Six-pac amp schematic | Sarge | Tubes / Valves | 1 | 31st July 2004 08:30 PM |
| Page generated in 0.08265 seconds (68.00% PHP - 32.00% MySQL) with 11 queries |
