Is this a C core OPT?
Old 11th October 2002, 03:30 AM   #1
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Is this a C core OPT?
It has both the primary & the seconday wrapped together -- it is a 10W EL86 PP for 800 ohm philips speakers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2002, 01:15 PM   #2
ultranalog is offline ultranalog  Poland
Send a message via AIM to ultranalog Send a message via Yahoo to ultranalog
I always though 800 ohm speakers were driven by OTL amps in the Philips radios.
C-core trannies usually have primary and secondary on the same assembly with the core around it. This is a type I've never seen before, where's the core anyway? Seems this would have poor coupling capabilities...
Remco
Old 11th October 2002, 01:47 PM   #3
HDTVman is offline HDTVman  United States
Hi Gents
Looks like a lumpted toroid with a laminated core to me, but what do I know.
Later
Bruce
What ever makes the tunes flow
Old 11th October 2002, 03:01 PM   #4
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Default You can "C" the gap.
Yep, they're C cores alright. At the bottom of the picture on the left you can see the small gap where the two halves of the core butt together. Two C shaped halves that face each other. They are made in a similar way to a toroid by winding a long strip of metal in a sort of square shape around a square thing. Then they are varnished and cooked. Then the core is cut into two halves and the abutting surfaces are polished to a smooth finish so they will fit together with minimum airgap (assuming an airgap is not wanted as in a conventional tranny).
GP.
Old 11th October 2002, 03:06 PM   #5
Oh, right. I through it was two windings perpendicularly crossed. Must be a slow day for my brain.
Still don't get why one would want to use an OPT for 800 Ohm speakers...
Remco
Old 11th October 2002, 04:54 PM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
it vaguely resembles a TV flyback tranny
Old 22nd October 2002, 01:38 AM   #7
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default PHILIPS
Dave,
Sorry but I somehow lost track of this.
in case you're still wondering:
These are definitely C-cores probably pull-outs from a Philips OTL.
These amps allowed for either low-z OPT couplig or C coupling to a 800R speaker.
I modded a few of those (in my less lazy period) and you can actually get pretty good sound from them even on more conventional speakers.
The circuitdiagram shows how they were operated with a pair of
EL86's.
I'm going to mail you that diagram.
Greetz,
Frank
Old 22nd October 2002, 02:43 AM   #8
frugal-phile(tm)
planet10's Avatar
Default Re: PHILIPS
Frank's picture is attached. I put these up on eBay and an astute bidder has informed me that these are double chokes for a Philips OTL. The amp, which had unquestionably had the smoke let out, is from a Philips organ and drove a 2-way 800 ohm speaker (12" + 6x8" whizzer cone mid-tweeter).
dave
Old 23rd October 2002, 12:25 AM   #9
fdegrove's Avatar
Default PHILIPS
Guys,
Any of our Dutchmen knowing of an online archive of Philips circuit diagrams to help Dave with this?
Thanks,
P.S. Headphone fans and SRPP afficionados take a good look:
very first SRPP used in an output stage!
Frank
Is this a C core OPT?Hide this!Advertise here!
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers Workhorse Solid State 14 4th April 2016 01:26 PM
inductor/choke/air core/ferrite core. . . same thing? poolorpond Pass Labs 24 29th March 2008 10:55 PM
Transformer efficiency - Z-11,H-14, c-core, r-core , toroidal flyboi Parts 23 4th May 2006 01:03 PM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
Copyright ©1999-2017 diyAudio
