diyAudio Sponsor
Old 2nd November 2005, 01:36 PM   #11
ingab is offline ingab  Italy
Can you reseed the attachment (is 0 byte!!!) or e-mail at my address:
andrea.bonelli3@tin.it
Thanx in advance
Andrea
Old 3rd November 2005, 12:55 AM   #12
Here is the schematic again.
It is grid-bias with a 249K resistor connected to a -23V DC. This part is out of this page.
I am thinking of turn it into cathode bias. But the B+ in this schematic is 450V and I can't find any reference with B+ of 450V.
Old 3rd November 2005, 11:25 PM   #13
Just a mite from me:
For some reason I could not download your circuit. I have tried to locate EL84 data that I have here somewhere, but also unsuccessful. But as I recall working an EL84 into 4K instead of 8K lowers the max. output to about 65% of the 8K value, with some rise in distortion. What mainly worries me is the quite high 450V on your EL84s. Not that they will spark, but at a maximum dissipation of 15W (anode + screen), you can draw a max. current of 34 mA/tube. Is this happening?
EL84 push pull slideman82 Tubes / Valves 4 19th June 2009 03:40 PM
Will this work for an EL84 push pull? zobsky Tubes / Valves 5 10th October 2006 07:42 PM
EL84 Push Pull amp. hacknet Tubes / Valves 8 23rd September 2004 05:53 AM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 06:04 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.15038 seconds (33.70% PHP - 66.30% MySQL) with 11 queries
