| diyAudio Sponsor | ||
I had a choke that I ordered by mistake, so I thought I'd play with it in a cap input supply. When I modeled it in PSUD, it showed a big reduction in B+ ripple with only a loss of about 10V. So I plugged it in per the following schematics. When I did the various measurements, the voltages all checked out as predicted, but my output hum went from less than 1mv to about 4mv. At first I thought it was the clip leads strung around, so I just removed the choke and extra cap and completed the circuit with the leads. Hum dropped back to <1mv, even moving the leads around. Could the choke be influencing the power transformer?
Edit: Thinking about it, I didn't ground the choke chassis. Could this be a problem? Amp: |
#2 |
Original supply:
#3 |
Choke and input cap:
Note that the only change other than cap and choke, is one less dropping resistor for the driver supply, to keep driver voltage the same. Taking this out did not affect the hum. |
#4 |
Hi Sheldon,
Was the supply loaded? Below a critical current the choke effect stops. At such low levels of ripple the core should be grounded and you may have to play with the choke orientation to prevent coupling with the power transformer. -Chris |
#5 |
Hi Cris,
Yes, the supply was loaded. I just power up the amp same as for the non-choke supply. No signal connection, but all systems go. I don't think orientation was the problem, as it was outside the amp and at least 10 cm away from the output transformers. Also, moving the choke around had no effect. Is it loading my ground in some way? Sheldon |
#6 |
The B+ tap is on the wrong side of the choke.
#7 |
hi
did you check the orientation of the choke? these things have a magnetic field around them, and unsurprisingly, it can couple with the output transformer. Try having the magentic cores at 90 degrees to each other. this is normal practice when building amps. Also, earth the case of the choke, or the laminations, this too keeps hum down. Hope that this helps. kind regards bill |
#8 |
According to your schematic, it is not a Choke Input LC filter. It is just a C-L-C PI filter. The 350V B+ should be tapped after the choke.
If you don't have hum problem with the original circuit, the hum probably caused by the magnetic flux generated from the choke and coupled to the OPT. Johnny |
#9 |
I noticed that the original power supply has a 100uF input capacitor. The second power supply has a 47uF input capacitor.
That would explain the higher hum level. I would move the B+ connection to the output side of the choke. Also. 100uF is too much capacitance. Most tubes are rated for 40uF to 60uF maximum. 100uF will shorten the life of your rectifier tube.
Frank |
#10 |
Sheldon.
What is the max rating for inductor current? Isn't it saturated while loaded? Pawel |
| Heat Induced Pressure in Cabinet? | tnsguy | Multi-Way | 7 | 15th February 2009 02:40 AM |
| cmoy bb , jds board, self induced woes | espressogeek | Chip Amps | 1 | 25th September 2008 04:59 PM |
| Fan induced noise, PG amp. | Safe_Cracker | Car Audio | 3 | 30th August 2005 06:14 PM |
| Pot induced noise? | Dominique | Parts | 0 | 10th August 2004 10:02 PM |
| transformer magnetic induced audio hum | Wardsweb | Chip Amps | 1 | 6th May 2004 08:54 PM |
| Page generated in 1.88805 seconds (4.80% PHP - 95.20% MySQL) with 11 queries |
