Wim's DC EL84 amp
EW published several d.c. coupled EL84 amps designed by Kees Heuvelman and Wim de Haan in January 2001. Wim has a link on his page to the design. Here's the link:
http://www.wdehaan.demon.nl/tubeamps/el84dc/index.html Here's a first cut at a pcb http://www.tech-diy.com/TubeDesigns/wims_el84_dc.gif i'm open to suggestions -- i am sure there are probably some glithces in the above. will furnish the Gerber files to anyone who asks -- I am only going to burn one board for my own use. |
Hi Jack,
At first sight: The cathode resistors dissipate a lot of heat. I think a heatsinked version would be a better choice. Anyway, the footprints look too small. The heaters' tracks for the ELs might be thicker and routed "one on top of another" with the same current flow direction. Regards, Milan P.S. Nice article in AudioXpress. |
Yes, they should dissipate ~ 10 W. The tracks for the heaterers are mostly 60 mils -- will have to give this some thought -- for the boards I do myself I like to have as much as possible on the bottom layer. The EL84 DC amp is going to power my St. Emillion Horns (in a modified wooden Bordeaux wine-box.) Thanks for the compliment -- National did all the heavy lifting, however. |
Hello Jack, nice job.
Which version of the ECC85 is it? I think Wim goes on to say that the version with the better ccs doesn't need feedback. Is yours it? Thanks, Phil. |
2 Attachment(s)
Hello jackinnj
I'm working on the same schematic, without PCB. So, this is my version: (I used ecc 83 instead of ecc85). I'm still working on the box. (I don't know the english word, "chassis" in french). Ciao! |
dave |
Dave -- I agree, the 60 mil trace width will poop out under the pressure of 7 tubes in parallel. |
OK, here's a 3D view -- I changed the resistors to the TO-220 style (Ohmite or Caddock, non-inductive) with heat sink -- they now take up a lot more space. I also removed the heater traces. Note that I try to take the grounds to the center of the board. I also use a "via" for connecting the top-layer traces -- helps when you are DIY'ing a board to have the darned hole there.
http://www.tech-diy.com/TubeDesigns/wims_el84_3D.gif here's the PCB: http://www.tech-diy.com/TubeDesigns/wims_el84_dc2.gif |
A very tempting design with all the ECC85s & EL84s i'm sitting on...
dave |
| All times are GMT. The time now is 02:32 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
