Wim's DC EL84 amp
Wim's DC EL84 amp
Old 12th July 2012, 06:49 PM   #41
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
Just wondering, did the TS finish that amp?
I never got mine to work, -it's been over a year- but I remember the ecc88 (6922) in the PS glowing bright purple, then I turned it off Never really dug into fault finding and recycled it into another amp
Old 12th July 2012, 10:24 PM   #42
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Several of those suggested circuits had way, way too much heater to cathode voltage for day-to-day use. A good way to use up some of the excess B+ voltage of lotsa vintage amps and modern line voltages though.
All good fortune,
Chris
Old 13th July 2012, 09:42 AM   #43
wimdehaan is offline wimdehaan  Netherlands
Default I never got mine to work
I build a final using the ECC85 + ECC88 (PSU+CCS) + EL84s and used it for 1 year without any problem, this 'normal' hours say 8 hours a week. Than this amplifier passed to one of collegues and he used it over the last say 8-10 years without any problems (in fact he is still suing using it now), he changed some years ago the tubes, not because they failed working, but just because he wanted some new tubes. So design seems very reliable.
Wim, author of the orginal EW+WW article
n/a
Old 13th July 2012, 02:43 PM   #44
rongon is offline rongon  United States
rongon's Avatar
I never got mine to work, -it's been over a year- but I remember the ecc88 (6922) in the PS glowing bright purple, then I turned it off ...
That sounds just like what happens to an ECC88 when the heater-to-cathode voltage is exceeded for too long... I remember bright purple-white sparks inside the tube.
Old 13th July 2012, 06:52 PM   #45
Default HV delay DC coupled designs
These DC coupled circuits will only work with a delay of the High Voltage, so first the heaters, than after 30 sec. the High Voltage
In the article it is mentioned that de HV supply should have a delay of at least 30 seconds. I made a little timer circuit with a delay of 1 minute. But 2 switches by hand works as well of course.
Normally I use floating heaters, this with two 100 resistors connected together with say a 1 uF capacitor to ground, works very well.
n/a
Old 22nd August 2012, 10:28 AM   #46
disco is offline disco  Netherlands
disco's Avatar
Strong performers indeed
jaap
Wim's DC EL84 ampHide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
El84 Pp Tobruk Tubes / Valves 1 1st May 2007 12:05 PM
EL84 PP Diy. Pls help me!!! BigOx Tubes / Valves 24 11th June 2006 06:09 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 07:19 AM
