Wim's DC EL84 amp
Wim's DC EL84 amp
Old 29th December 2010, 06:42 PM   #31
kevinkr's Avatar
Wim's DC EL84 amp
Originally Posted by SY View Post
But at 24mA as in SB's tests? Even with a grid resistance as low as 10k and a swing as high as 100V, the signal current is a small fraction of that.
Quite true, I'm not saying this is a realistic test.. It does serve to illustrate the effect, and some of these things can be measured at levels that can reasonably be expected in driver applications.
Low mu DHTs may require swings of 300vpp and into 10K this would be 30mApp. The 50 dht is a perfect example as 10K is the maximum permissible grid circuit resistance - if not IT coupled will require grid drive approaching 17mApp under the stated conditions for full output. In some cases a grid choke will be used that obviously substantially reduces the current drive requirement, but I have also seen RC coupled 50 amps in the past.
In a passive X-O the currents can be far higher, usually the voltages are much lower except in pro applications where these sorts of voltages may be seen at very high currents. Bi or tri-amping makes a lot of sense in such applications, but isn't always done.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th December 2010, 06:47 PM   #32
On Hiatus
SY's Avatar
Wim's DC EL84 amp
Agreed, that's where I've certainly seen, errr, heard the greatest differences between caps.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 29th December 2010, 06:53 PM   #33
kevinkr's Avatar
Wim's DC EL84 amp
Originally Posted by artosalo View Post
Some of us here think that all capacitors at the signal path are harmful with respect to sound quality of an amplifier.
Should we then concentrate to construct dc-coupled tube amplifiers only ?
Would such amplifers sound better ?
How many capacitors have the music we play already passed thru before it reach our tube amplifier and its last two to three capacitors - those that are claimed to create distortion to the sound ?
What about these earlier "some 50 pcs." during the chain from the instruments via the studio etc. etc. and finally out from our CD player ? Don't these have the same effect ?
If they had, why should we then concentrate to get rid of these last few capacitors ?
I fully agree that zero-biased tantalum or electrolytics are not the best capacitors in the signal path.
FWIW I more or less completely agree with everything you said in the above quoted post. I have quite a few high quality film caps in the signal path of my electronics along with quite a few more transformers than are typical in most modern systems. Vintage recordings were recorded, mixed down and mastered on equipment full of transformers, tubes, and paper coupling caps. Newer recordings have some of the above in addition to sometimes mediocre op-amps and other less delectable items in the signal path. Even worse I mostly listen to vinyl these days using a table, arm and cartridge all designed more than 40 years ago..
Old 29th December 2010, 07:16 PM   #34
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
What's the use of diyaudio anyway if you look at it that way?
I myself don't care whatever happened in the studio etc. The part of the chain I have influence on is what I try to get as good as possible.
Old 29th December 2010, 07:18 PM   #35
Guido Tent is offline Guido Tent  Netherlands
To avoid making it worse - you don't know how it would have been without those caps.
Avoid them, and if possible, reduce the charge density as much as possible (i.e. work with high impedances).
Guido Tent
www.Tentlabs.com
Old 29th December 2010, 08:00 PM   #36
artosalo is offline artosalo  Finland
artosalo's Avatar
So when those "50 pcs." of capacitors are still there without our control, can you still (seriously) claim that the sound will be improved if you get rid of the last three ?
Or you only belive so ?
Old 29th December 2010, 08:34 PM   #37
Miniwatt's Avatar
I'm not here to get stuck in this kind of endless discussions
I stated earlier that getting rid of one cap improved things in my opinion.
If you call that 'belief' that's fine, I'm not a machine.
Old 29th December 2010, 10:10 PM   #38
M Gregg is offline M Gregg  England
I have found similar improvement changing Output op amps on DAC's IE NE5534 to OP27. Even the make of the same Op amp has shown a difference in the same circuit. I think we have to accept the best source we can afford to buy or build and then say we must try to preserve the input to the amp in tact.(with as little addition or distortion as possible).
The next task for us is to raise the level of the source to a power that can drive our speakers in the best possible way.
Or with the most enjoyable presentation possible with the limitations imposed on us (money-component cost)
Then make it so good that as we improve the source the amp can still out perform it. (That is the hard part). We have to "forget" the source and say what ever goes in must be exactly what comes out nothing added or taken away!<<that is even harder if not impossible!
M. Gregg
Old 30th December 2010, 08:22 AM   #39
artosalo's Avatar
If you are sure that the sound quality changes, then there are very potential chance that some measurable difference can be found with other "tools" than human ear too.
I sincerely strongly recommend you to go deeper into this observation.
If you found something, this would be very valuable and real science.
Old 30th December 2010, 09:11 AM   #40
Just a thought,
I think DC coupling is sonically better, however it is not as much "fun" from a build point of view. With AC coupling each stage is "protected" from the failure of the tube in the previous stage by the capacitor. So measures would have to be put in to protect OP tubes and Tx's.
I like to think of topologies in categories:
LoFi, HiFi, SuperFi.
LoFi quick projects that are fun to build and give good results.
Hifi can be great fun and give real satisfaction to the builder. Built to good designs and using a few esoteric ideas.
Superfi can be a pain in the A** constant tweaking and weak sources showing their faults. However it can be very interesting. The trouble is you always think it could be better and each improvement is harder to get than the last.(cutting edge comes to mind).
So I think there will always be a need for good designs with AC coupling caps! That is why they are so popular now.
M. Gregg
Wim's DC EL84 ampHide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
El84 Pp Tobruk Tubes / Valves 1 1st May 2007 12:05 PM
EL84 PP Diy. Pls help me!!! BigOx Tubes / Valves 24 11th June 2006 06:09 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 07:19 AM
