Wim's DC EL84 amp
Wim's DC EL84 amp
Old 27th October 2005, 07:14 PM   #11
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Wim's DC EL84 amp
Originally posted by jackinnj
hate to think of pulling the shards out ---
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th October 2005, 08:39 AM   #12
moamps is offline moamps  Croatia
At second sight:
- Ia metering on only one tube
- no one PS bypass cap on board
- R23's gnd may be routed to ECC88's "9" pin
- reversed 200R trimmers.
Milan
Old 28th October 2005, 08:57 AM   #13
Guido Tent is offline Guido Tent  Netherlands
This is version 4 -- with the ECC88 current source -- but I am going to outboard the -150V/+206V supply -- so both halves of the ECC88 are used for two amps on one board.
Dave -- I agree, the 60 mil trace width will poop out under the pressure of 7 tubes in parallel.
Hi
I'd sugest to connect both EL84 cathodes to each other, and leave the decoupling caps out.
This requires tightly matched valves and good DC balance from the driver.
best
Guido Tent
www.Tentlabs.com
Old 29th October 2005, 09:40 AM   #14
VanguardVillage is offline VanguardVillage  China
Send a message via MSN to VanguardVillage
Default where is the schematics?
can i have a look ?
Old 29th October 2005, 10:25 AM   #15
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
Wim's DC EL84 amp
can i have a look ?
Here it goes:
http://www.wdehaan.demon.nl/tubeamps/el84dc/
Old 28th December 2010, 01:40 PM   #16
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
This came up on Google, I'm preparing to build the last version in the article.
Just one small question: what's the function of the (volt?) meter and resistor between the cathodes of the power tubes? And what range should it be, 100 V?
Cheers
Old 28th December 2010, 01:54 PM   #17
kevinkr's Avatar
Wim's DC EL84 amp
Link to article here: http://www.wimdehaan.nl/downloads/dccoupledamp.pdf
FWIW other comments not withstanding I would build the circuit as described in the article, and then modify if so inclined. High quality cathode bypass caps are a must however..
The meter is used to establish overall DC balance in the amplifier. Meter is a 50uA-0-50uA type as mentioned in the early paragraphs of the article.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th December 2010, 05:23 PM   #18
artosalo is offline artosalo  Finland
artosalo's Avatar
The article is based on one assumption: (quote of the author)
" I believe that coupling capacitors have a major influence on the overall sound quality of an amplifier."
Have we so far got any evidence that this would be the case ?
I have not seen such.
That could be an interesting and distinctive project to build, but the test results published at the article do not show any excellence over normal construction with coupling capacitors.
Old 28th December 2010, 05:28 PM   #19
kevinkr's Avatar
Wim's DC EL84 amp
Actually I believe this based on long experience designing audio gear, but I also believe it is much easier to find an electrically blameless and good sounding film coupling cap than it is to find an equally good sounding cathode bypass cap regardless of cost. (By good sounding I mean transparent, and audibly artifact free. And yes I have done some single blind testing with coupling caps and a small listening panel. The result of that is that I now use mostly teflon/foil coupling caps. The Russian FT-3 is good and not too expensive a place to start. I use TFTs and Vcaps mostly.)
Old 28th December 2010, 05:36 PM   #20
Miniwatt's Avatar
I got rid of a gain stage (and thus a coupling cap) in my power amp because my preamp has enough gain, and that really cleared things up. So much so I got very interested in dc coupling. But no 'scientific evidence'..
(And I started thinking..)
Everyone will agree looking through an open window gives a better view then through glass. You can debate which sort of glass is the clearest, but no glass is always better..
Wim's DC EL84 ampHide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
El84 Pp Tobruk Tubes / Valves 1 1st May 2007 12:05 PM
EL84 PP Diy. Pls help me!!! BigOx Tubes / Valves 24 11th June 2006 06:09 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 07:19 AM
