| diyAudio Sponsor | ||
my goal is to build a guitar amp, a Class-A, single ended, ~5w-7w amp with 12ax7 (2 of them?) in the pre-amp and 1 EL84 for the power.
i chose classA single ended because i believe this is the simplest? correct me if im wrong. im a newbie and have been searching this forum but i cant seem to find what im looking for. do you guys know links that i can go regarding this project? or maybe you can help me directly through this thread thanks |
#2 |
Dear Buliwyf,
Let's visit this page: http://www.ax84.com/?pg=projects The http://www.ax84.com/index.php?pg=projects&project=p1 is exaxtly what you looking for. A EL84-SE guitar amp with 12AX7 preamp tube, and with 5-7W output power. All other infos are on the link. Photos, schematic, etc... Good luck, respect from Hungary |
| 5W EL84 drive EL84 SE | Audio_idiot | Tubes / Valves | 31 | Yesterday 08:38 PM |
| 12ax7 | nigelwright7557 | Tubes / Valves | 6 | 1st June 2008 02:54 PM |
| 12AX7 how many is enough? | Sambeaux | Tubes / Valves | 19 | 23rd March 2007 07:31 PM |
| OLT Headphone amp useing two EL84's & a 12ax7? | ak_47_boy | Headphone Systems | 3 | 24th December 2006 07:58 AM |
| FS: Vacuum Tubes (12au7, 12ax7, 6dj8, EL84) | mrdon | Swap Meet | 4 | 28th October 2006 08:13 PM |
| Page generated in 0.32707 seconds (17.67% PHP - 82.33% MySQL) with 10 queries |
