diyAudio Sponsor
Old 25th October 2005, 01:09 PM   #1
porkchop61's Avatar
Question Using PSU Designer to calculate DC filament supply
I'm trying to use the PSUD2 to design a DC filament supply for 2 6SN7 tubes.
I assume you use a resistive load because its a heater, but where do I find the value of the resistance? I also assume that this resistance changes as the tube heats up.
I've never used DC for heaters, so I thought I'd give it a try.
Are the heaters still wired in parallel as AC heaters are?
Thanks in advance.
Glenn
Old 25th October 2005, 01:50 PM   #2
Default load resistance for PSU designer
Use a resistive load of 6.3 V / .6 A = 10.5 ohms. This is the hot value, valid after 15 or 20 seconds. Yes the initial value is lower, and your simulation for the first 15 seconds will be inaccurate, but so what ? I think you are really only interested in the steady state DC voltage and ripple.
As for series or parallel, that depends on wether you have 12.6 volts ( use series ) or 6.3 volts ( use parallel ) available.
Robert McLean
Old 25th October 2005, 04:27 PM   #3
porkchop61's Avatar
Thank you Robert
I have 6.3 volts, so I'll be using that.
Glenn
Old 25th October 2005, 04:33 PM   #4
porkchop61's Avatar
Is the 0.6A is for 2 tubes in parallel?
Old 25th October 2005, 04:49 PM   #5
Yvesm is offline Yvesm  France
Yvesm's Avatar
Try to set heathers in serie: less current, easier to filter, smaller caps, lower current peaks
a win win approach !
Yves.
Old 25th October 2005, 05:05 PM   #6
porkchop61's Avatar
Using the series approach, if one tube heater fails the whole heater circuit fails, correct? I'm not sure this is a good or bad thing. I guess you can't use the circuit either way (series or parallel). The only hard part would be troubleshooting which tube failed.
Glenn
Old 25th October 2005, 06:28 PM   #7
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
You don't need to know the resistance if you use the constant current load option in PSUD2.
Series or individual is much safer than parallel, because of the potential voltage rise when one valve is removed.
Why do you need DC? It can be noisier than AC!
Old 25th October 2005, 06:42 PM   #8
astouffer's Avatar
How can DC be noiser than AC?
Old 25th October 2005, 06:51 PM   #9
dhaen's Avatar
Diode noise. Hum is easily managed by twisted wiring and centre-tapped (or resistively divided) windings, referenced to ground. Indirectly heated filaments were created for this very purpose.
Old 25th October 2005, 08:01 PM   #10
porkchop61's Avatar
Yes, I've never had a need for DC heaters in the past, but I like to have a "plan B" if needed. It's also another thing I'd like to experiment with just because I've never done it.
This is for a line level 2 tube 6SN7 preamp, so the wiring is pretty simple compared to other jobs I've done.
I never thought about the voltage rise if a tube is removed, good point. Of course I would never do such a thing
Here's my layout so far:
6SN7 preamp
Glenn
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 12:59 AM
Yet another DHT filament supply astouffer Tubes / Valves 25 5th July 2009 11:08 PM
Modelling a DC filament supply in PSU Designer II G Tubes / Valves 3 7th February 2008 10:59 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 05:03 AM
Page generated in 0.08834 seconds (82.82% PHP - 17.18% MySQL) with 10 queries
