| diyAudio Sponsor | ||
Hi all-
Can someone tell me why some PSU's have a small (0.1uF or so) non-electrolytic capacitor across the rails? Is this for RF noise? Does the position on the PSU rail matter? Sorry for all the questions. Glenn |
#2 |
It is used to bypass higher frequencies where the usual electrolytic becomes ineffective. The best position is as close to the circuit being bypassed as possible.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
what i do is.solder the leads of small caps to board such that long leads of cap is still left.i connect the circuit wires to those leads so that max noise bipassing is achieved.its really a very imp thing and must never be missed
#4 |
Here's a URL to a good article on filter/bypass caps.
http://www.seattlerobotics.org/encod...97/basics.html This is a short summary: Another great place for a bypass cap is on power connectors. Anytime you have a power line heading off to another board or long wire, I would recommend putting in a bypass cap. Any long length of wire is going to act like a little antenna. It will pick up electrical noise from any magnetic field. I always put a bypass cap on both ends of such lengths of wire. Bypass capacitors help filter the electrical noise out of your circuits. They do this by removing the alternating currents caused by ripple voltage. Most digital circuits have at least a couple of bypass capacitors. A good rule of thumb is to add one bypass capacitor for every integrated circuit on your board. A good default value for a bypass cap is 0.1uF. |
#5 |
good one james.
great piece of info |
#6 |
Thanks for the reply everyone!
I think I'll add one to the B+ right before it goes into the first tube. Glenn |
#7 |
diyAudio Moderator Emeritus
Yes, good advice! I think, also, that a small cap is also useful across the output of an SS bridge, to help suppress hash.
| Does somebody know the purpose of YM3613B? | guytou | Digital Line Level | 24 | 23rd June 2009 05:52 PM |
| What is the purpose of the g2 bypass cap? | leadbelly | Tubes / Valves | 3 | 16th August 2008 05:43 PM |
| Chassis for DIY purpose | Sampartners2006 | Everything Else | 9 | 6th September 2006 09:29 PM |
| What is the purpose of NE5534 in this amp | Gasho | Solid State | 12 | 11th April 2005 12:02 AM |
| What's the purpose of this LRC in this xover? | andy2 | Multi-Way | 1 | 27th February 2005 03:48 AM |
| Page generated in 0.11088 seconds (65.81% PHP - 34.19% MySQL) with 10 queries |
