Hello,
I look for any inside, outside pictures about EAR859 amplifier. Please, if you have any pictures about this amplifier send to me! Thanks drobert |
#2 |
Dear Drobert,
A small photo attached, maybe it helps you. Regards, |
#3 |
It's very nice, but I would a lief look for a inside picture about this amplifier.
Thanks drobert |
#5 |
#6 |
diyAudio Moderator Emeritus
#7 |
Tim drew out the first stage of this and I thought, "That looks absolutely goofy." Current trickled though an ECC88 cascode? But when I breadboarded and tested it, it turned out to work superbly well. This would be a fine input stage for any power amp where it can be buffered.
If there's a sucker born every minute, where do the rest of them come from? |
#8 |
Hi Sy,
its nice to hear good things about TdeP's design. I have built the amp though I have changed the CF to a cascoded fet source follower, and played around with plate to plate feedback. Do you have any thoughts about the pros and cons of the level shifting (is that the correct term) scheme between the cascode and the CF? I would guess that a similar design could be used for other zero bias tubes such as the 811a. Any thoughts? best regards, tim (a different tim) |
| Pictures of my T-Amp. | hsu | Class D | 5 | 14th February 2007 04:06 AM |
| About me with many pictures... | Lord_Magnepan | Introductions | 1 | 30th March 2005 04:28 PM |
| New SOZ with pictures! | cjunk | Pass Labs | 40 | 2nd February 2003 07:52 PM |
