diyAudio Sponsor
Old 23rd October 2005, 07:49 PM   #31
aletheian's Avatar
Originally posted by jlsem
Steel leads will have less skin effect than copper because iron has much higher susceptability than copper. As a matter of fact, in a resistor lead, skin effect is practically nonexsistant even at high frequencies.
John
Yeah, the issue that I am concerned about is copper clad steel wire leads in the audio path. It would seem that varying resistance at differing frequencies would result.
Heghlu'meH QaQ jajvam!
Old 23rd October 2005, 09:46 PM   #32
anatech is offline anatech  Canada
anatech's Avatar
This would not be significant at all at these frequencies and currents. Or, maybe it's like bi-wiring. I can just see this debate.
-Chris
What on earth are these woofers I bought on eBay? Spasticteapot Multi-Way 3 30th September 2008 03:48 AM
Bought a sub from ebay - arrived damaged. Now what? *pics* MikeHunt79 Subwoofers 19 26th February 2008 08:28 PM
Russian paper in oil caps - any good? PRNDL Tubes / Valves 18 27th September 2007 10:58 PM
Ebay Russian teflon caps tiroth Parts 7 27th May 2002 07:39 PM
Page generated in 0.07119 seconds (66.06% PHP - 33.94% MySQL) with 11 queries
