diyAudio Sponsor
Old 22nd October 2005, 10:57 PM   #21
aletheian's Avatar
Amen to that.
They were made in 1990, but Russia used PCB's for a long time after the USA stopped in the 70's.
Heghlu'meH QaQ jajvam!
Old 22nd October 2005, 10:58 PM   #22
Sheldon is offline Sheldon  United States
Originally posted by anatech
Hi Sheldon,
It depends on the frequency as to whether the lead inductance is important. Generally not at audio frequencies, unless the circuit responds at high frequencies as well.
-Chris
Understood, that's why I was looked up wire inductance as I said in my post. Sorry if I wasn't clear, but my question wasn't asking about the importance of inductance. The thread starting post was making an assumption that steel wire or casing for a cap would cause increased inductance. I was questioning the notion that steel wire is more inductive than copper wire. The story is different for a transformer core or maybe a coil of wire, but this concerns only a straight lead. The cap case being on the outside shouldn't create an inductance problem either, should it?
Sheldon
Old 22nd October 2005, 11:16 PM   #23
anatech is offline anatech  Canada
anatech's Avatar
Sorry Sheldon,
I thought that was a strange question from you. The material affects only the conductivity. That may affect the quality factor of the inductance, but the physical dimensions and layout determine the inductance. The case on the outside would act as a shield.
-Chris
Old 22nd October 2005, 11:23 PM   #24
Thanks, that was my assumption. I just wanted to confirm it.
Sheldon
Old 22nd October 2005, 11:58 PM   #25
aletheian's Avatar
Well, that's mutual inductance and self inductance in coils according to Lenz's Law, yes. Surely a ferrous material has more self inductance than a non ferrous material? Ferrous materials have a much much higher permeability. WE're talking about reactance to and generation of fields here right?
Maybe I am missing something...and forgive me if I am...
Induction in itself is one thing if we are talking about straight up Henries, but it is also it is a factor in different equasions, like u factor for example. Skin effect is caused by self-inductance... and in a clad wire, it will effect the audio band starting at 2K and moving down to 300hz. So to say that the lead composition doesn't make a difference in the audio spectrum, well I can't agree with that. Maybe the straight up inductance of copper leads vs steel leads is not important until you get into RF bands, but there are so many other issues related to ferrous lead material that can be pushed out of the audio spectrum by not using steel in the signal path. I mean, B-h curves do exist. This is not just a marketing gimmic from Cardas and REL.
Old 23rd October 2005, 12:41 AM   #26
anatech's Avatar
The effect depends on the current flow and the wire thickness. I doubt there is much to talk about in a straight piece of wire. We would not tend to coil wire to a cap unless we wanted to make an RF trap. The other thing to consider is that it is difficult to solder to iron or steel.
In reality, at audio frequencies, you need the lines of force to cut across one or more conductors carrying the same signal to create a meaningful inductance. An iron core would certainly help. I'll accept a ferrite core. I have not seen the leads of many capacitors arranged like that.
-Chris
Old 23rd October 2005, 01:21 AM   #27
aletheian's Avatar
-Chris
Fair enough. i guess the magnetic flux in a staright conductor is somewhat moot in audio, now if you were building a railgun on the other hand....
Old 23rd October 2005, 01:24 AM   #28
aletheian's Avatar
...but I am still going to use non-inductive resistors/capacitors for my grid stoppers and crossovers...
Old 23rd October 2005, 01:30 AM   #29
anatech's Avatar
Good idea, you are now talking RF frequencies.
-Chris
Old 23rd October 2005, 03:44 PM   #30
jlsem is offline jlsem  United States
jlsem's Avatar
Steel leads will have less skin effect than copper because iron has much higher susceptability than copper. As a matter of fact, in a resistor lead, skin effect is practically nonexsistant even at high frequencies.
John
What on earth are these woofers I bought on eBay? Spasticteapot Multi-Way 3 30th September 2008 03:48 AM
Bought a sub from ebay - arrived damaged. Now what? *pics* MikeHunt79 Subwoofers 19 26th February 2008 08:28 PM
Russian paper in oil caps - any good? PRNDL Tubes / Valves 18 27th September 2007 10:58 PM
Ebay Russian teflon caps tiroth Parts 7 27th May 2002 07:39 PM
Page generated in 0.10800 seconds (79.64% PHP - 20.36% MySQL) with 11 queries
