Can someone help me with DIY hybrid preamp? 2sk170 - 6dj8 - cascode - diyAudio
Old 8th October 2002, 12:56 AM   #1
Default Can someone help me with DIY hybrid preamp? 2sk170 - 6dj8 - cascode
HI!
I have been working on this preamp for a few days. I'm not really following any formulas because I'm not good at that stuff at the moment. However, I love tweaking wires and using jumper cables to get things working.
I'm making this mainly as a guitar preamp but hope to use it with other things as well. It can handle about 1 volt (ac) input without clipping. 1 volt in gets me about 18 volts out.
right now I just have one stage (2 - cascode) and things seem to sound really good. I'm just wondering if some of you more experienced people can let me know what you think or give some ideas of how i can make it better.
Also, how would i correctly put a volume (more like a gain control) in this thing?
Future plans are to capacitively couple to an EF86 (as a cathode follower), and then into the remaining 6DJ8... maybe as a mu follower of some kind. I then want to sample some of the ouput, rectify it (negative), filter, and run it into the EF86 to control the gain of the EF86 (hopefully resembling a compressor of sorts!).
Anyway, here it is. I hope some of you take a look and leave a few comments!!
Thanks,
Matt M.
Old 8th October 2002, 12:58 AM   #2
Doh! The output actually comes from the plate!!! and the grid resistor is 1M.
Sorry about that!
- Matt
Old 5th May 2012, 01:17 PM   #3
triode_al's Avatar
funny find this circuit idea from 2002, ten years ago, even when it is diagrammed wrong (output is from plate):
there is a DC feedback from plate to source, 2M/2k2= 60db amplification. Fixed. Not bad in concept.
60 dB bit hefty though and I think impossible to realize.
But 45db should be possible with this combo. [I did that without feedback].
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
6DJ8 or 12xx7 for hybrid amp (Monarchy) Interious Tubes / Valves 56 6th December 2008 05:46 AM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Hybrid Cascode ? Eli Duttman Tubes / Valves 3 9th May 2006 11:35 PM
TX103 - RJM 6DJ8 - TX102 preamp Paul Ebert Tubes / Valves 3 2nd July 2005 09:14 PM
6DJ8 preamp voltage? needtubes Tubes / Valves 1 2nd April 2004 09:06 AM
Copyright 1999-2017 diyAudio
