LongTailedPair gain -> how to calculate? LongTailedPair gain -> how to calculate? - Page 2 - diyAudio
Old 21st October 2005, 08:57 PM   #11
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Why do people mostly use semiconductor CCS, and not tube-CCS? I have seen many tube-amplifier schematics, but just a few of them use tube based constant current source. Is it only, becouse of a MJE340, or BC546 is far more cheaper than a tube?
No, that's not the reason. A VT CCS requires a large, negative PS applied to the cathode of the CCS tube. Here is part of a design I'm working on (see attached). Given the voltages, the solid state CCS requires no additional power supply. To substitute a pentode for the cascoded transistors, you'd need a negative supply of, let's say -150V. If you already have such a supply, for fixed bias, then it's NBD. If you don't, then it's an extra complication that can easily be avoided.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 21st October 2005, 09:00 PM   #12
On Hiatus
SY's Avatar
A tube CCS will require a much larger voltage drop, a separate set of heater supplies, and for all of that will not give any better performance than a couple of bipolars. Often worse.
For all of that, some people love 'em and use 'em.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 22nd October 2005, 06:20 AM   #13
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
I do! I haven't had a happy time trying to mix SS with vacuum devices (except for SS rectifiers, of course).
I've found a 6AU6 pentode to be easy to use and effective as a CCS, in the tail of a 6SL7 LTP which has its grounded grid at true ground (0v). My negative rail is -110v. I make sure the heater of the 6AU6 is at a safe voltage that doesn't exceed the rated heater-cathode voltage limit 0f 100v.
Current per triode in the LTP is 0.8mA, which means the plate current of the 6AU6 is 1.6mA. Voltage from 6AU6 plate to cathode is 112v, screen to cathode is 95v. If you look at the 6AU6 plate curves for screen voltage ~100v, you will see that they are very flat for such a low current. The plate current appears to be constant within 0.01%. For more current, e.g. as a CCS for a 6SN7 LTP, a negative rail of 150v would be preferable.
Old 22nd October 2005, 03:47 PM   #14
aletheian is offline aletheian  United States
aletheian's Avatar
Default Re: LongTailedPair gain -> how to calculate?
How can I calculate the voltage-gain of this stage?
Thanks in advance!
I dug up these "rule of thumb" quick and dirty calculations from my archives. I think they were posted by Steve Bench on a forum somewhere:
"Differential amplifier (phase splitter etc) made from a 12AX7.
The plate load resistors are 150k each, and the next stage grid resistors are 220k. The cathodes are tied together and fed from a 2 mA current source.
What is the gain from either input to either output?
Solution: Effective Plate Resistance = 71k (plate resistance for these bias conditions) paralleled by 150k, paralleled by 220k or about 39k.
Effective cathode resistance. The current source is assumed to have a very high resistance, so may be neglected. Each cathode is "looking at" the other cathode. The gm under these bias conditions is about 1400 umhos (710 ohms). Therefore the cathode resistance is 710 + 710 or about 1420 ohms.
Stage gain = 39000/1420 = 27.5. Note that the differential gain (one input to both outputs) is double this (55), since equal and opposite output is provided by each plate.
This method also works for sand state devices as well."
Heghlu'meH QaQ jajvam!
LongTailedPair gain -> how to calculate?Hide this!Advertise here!
How to calculate gain and output impedance? RogerGustavsson Solid State 1 7th June 2008 05:09 PM
How to calculate gain? lumanauw Solid State 10 29th July 2007 12:57 AM
Have to calculate gain for typical small JFET preamplifier supernet Solid State 4 11th August 2006 11:22 PM
How to calculate the gain of an input-driver stage? Antonio Tucci Tubes / Valves 0 8th October 2004 12:25 PM
Copyright ©1999-2017 diyAudio
