diyAudio Sponsor
Old 20th October 2005, 11:47 AM   #1
jackinnj's Avatar
Default RIAA "Tube Simulations"
I just put together some RIAA simulations -- the original Dynaco PAS, Koren's modification, the Audio Research SP3a and SP8. Here's what the deviation from the standardized RIAA curve look like:
Old 20th October 2005, 01:43 PM   #2
jackinnj's Avatar
I should have stated -- these are the deviation (error) in dB from the standardized RIAA curve.
Old 21st October 2005, 10:48 AM   #3
jackinnj's Avatar
Here's the actual "measured" results from my PAS preamplifier -- note the difference from that calculated by SPICE from the schematic. Note that the output is taken without intervention of the balance or tone controls.
Old 10th September 2010, 10:25 PM   #4
drdagor is offline drdagor  United States
Yup... That sure looks like a curve that could have come off the PAS I had in college. It worked great with the little AR 4a and such, which tended to roll off starting at about 100 Hz. Dynaco may even have designed the PAS to boost the bass a little.
Dr. Dagor
Old 10th September 2010, 11:24 PM   #5
And at a max of 2dB it ain't much, might add a little robustness to the flavor . I wouldn't be surprised if cartridge loading might not have just as much effect on deviations (though probably on the other end of the spectrum).
mike - www.keepingsundayspecial.org
Kofi Annan in: "Cascodin' with Steve Bench's RIAA!" Kofi Annan Tubes / Valves 261 10th June 2011 05:48 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"All American" RIAA Preamp wrenchone Analogue Source 33 13th March 2008 07:05 AM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 05:28 PM
"Improved RIAA by Jax"-Power supply help needed!!! brigade77 Tubes / Valves 2 9th May 2006 05:04 PM
Page generated in 0.22349 seconds (33.65% PHP - 66.35% MySQL) with 10 queries
