diyAudio Sponsor
Old 19th October 2005, 02:35 PM   #1
drobert is offline drobert  Hungary
Default 6sn7 pre
hello,
I look for a link to this schematic. Can anybody help me?
drobert
Old 19th October 2005, 03:20 PM   #2
kmtang is offline kmtang  Canada
kmtang's Avatar
Default JE Lab
Take a look at the JE Lab's line stage. It is very simple but with very good sound.
73
Johnny
Old 19th October 2005, 03:25 PM   #3
kmtang's Avatar
Here is the link.
http://members.myactv.net/~je2a3/jelphono.htm
Old 20th October 2005, 08:36 AM   #4
Hello Johny
Thanks a lot your answer, but I think that you misunderstanded me.
I look for a web page where there is this scematic because I need to the descreption for this.
drobert
Old 20th October 2005, 02:47 PM   #5
amperex is offline amperex  United States
Default I do not understand your reply
When I view a schematic & parts lists of a design, the entire design is automatically converted to my verbal language of english. In other words, I guess I see the trees in the forest, just not the forest itself.
Old 24th October 2005, 01:13 AM   #6
What is unclear?
you have a power supply which will deliver ~240V. The 6SN7 runs its heaters on AC. It has ~6kOhm output Z( excepting where the coupling cap takes over and dominates at lower frequency ).
You should be able to get it working almost anything which is even close to what is described on that schematic.
I'd suggest a higher B+, and double the plate load resistor. 32-34kOhm is a nice load line when B+ is ~440VDC. Drop 250 of those volts across the plate load, for about 6-8 mA.
cheers,
Douglas
the Tnuctipun will return
6SN7 pre-amp Andersen Tubes / Valves 57 17th July 2011 07:00 PM
SE 6SN7 amp.... JandG Tubes / Valves 24 6th March 2011 12:37 PM
6sn7's irishguy170 Swap Meet 0 15th January 2008 08:09 AM
Help me.......What is the 6SN7 ??????? cd149dc Tubes / Valves 10 17th June 2007 05:09 PM
Is it the 6SN7 or me? arnoldc Tubes / Valves 4 13th October 2006 12:31 AM
Page generated in 0.07948 seconds (72.29% PHP - 27.71% MySQL) with 11 queries
