diyAudio Sponsor
Old 18th October 2005, 02:01 AM   #1
layt is offline layt  Australia
Default My first (guitar) amplifier
Ive finally finished my first amplifier!, Its a Fender princeton 5F2 circuit and I love it!. Makes my new blues junior sound ordinary in comparison and also hisses and carries on alot less. Im using the speaker in the blues junior at the moment and it makes the amplifier rattle like ive never heard it before, im guessing the reverb tank and/or the springs holding the power tubes are to blame. The only real problem im having is the tone pot does nothing at all and im not sure why, could i have destroyed it somehow? It seems very loose and easy to turn compared to the volume. Its definitely wired up properly so something must be fried somewhere (im sure its the pot). Even without a tone control though its still great, thanks to everyone who answered my stupid questions and prevented me from frying power transformers, myself etc etc. My next project will be a 15watter with reverb (goodbye blues junior).
Old 18th October 2005, 02:32 AM   #2
Robski666's Avatar
Hi Layt,
good on ya you one step ahead of me, all mine have been "sand state" so far! not knowing the circuit power it off! and use your meter and check the tone pot should get the nominal r value from the outside connections and the wiper the middle connection should act as a divider between either outside connection, varying as you rotate the pot.
another gotcher is the curve of the pot although this would usually be a case of nothing much changes untill you rotate the pot to either extreme. ie log vs lin.
rattle whats rattling?
Robert
Old 18th October 2005, 03:17 AM   #3
aletheian's Avatar
Default Re: My first (guitar) amplifier
Hey man,
you should check out http://ax84.com/bbs/ for great info on guitar amp stuff.
Heghlu'meH QaQ jajvam!
Old 18th October 2005, 05:26 PM   #4
Trout is offline Trout  United States
Trout's Avatar
Might not be a bad idea to just switch it to the 5F2-A setup. If the 250K pot is questionable. The 5F2-A uses a couple less parts and (2) 1 Meg pots.
5F2-A Schematic
I have been fighting my recent Fender Build a few days myself. I built the Champ AA-764 but used a PT strong enough for 3 of them LOL
Gene
PS, Thou Must Post Pics
Old 19th October 2005, 01:55 AM   #5
Default heres some pictures
hope they work this time!
Old 19th October 2005, 02:00 AM   #6
Default another
cant i attach multiple images to the same post??, ah well ill just do it this way
Old 19th October 2005, 02:02 AM   #7
last one
Old 19th October 2005, 09:26 AM   #8
Cassiel is offline Cassiel  Botswana
Cassiel's Avatar
Hi layt,
The blues junior sounds quite nice, i would like to know what do you like about the Princeton that doesn't have the blues junior.
Thanks,
Al.
Old 22nd October 2005, 12:27 AM   #9
The blues junior just doesnt have the bass like the little princeton (I can play with the tone controls all I like but it just cant come close), it has a much thinner sound and it doesnt respond to my playing as well either. Also the princeton has less background noise than the blues junior, even with no reverb whatsoever the junior carries on and hisses and makes a racket. Not that the junior sounds bad, I just prefer the sound of the princeton and I can crank it in the bedroom whenever I like and not bother my household quite as much. Its probably also that I built the princeton myself, so im a bit biased....
Old 22nd October 2005, 01:06 AM   #10
Cassiel's Avatar
Not really, it's not the first time i hear that... Actually this is the second time i hear, from someone who has had both amps, that the Princeton sounds better.
Just wanted to be sure, i was about to buy one.
Thanks for your reply.
Al.
i want to build a guitar amplifier elmer Instruments and Amps 24 30th March 2010 06:52 PM
2a3 Triode Guitar Amplifier 2a3geek Instruments and Amps 2 23rd November 2008 08:34 PM
807 Guitar Amplifier guitar88 Tubes / Valves 0 1st April 2008 03:34 AM
DIY guitar amplifier suggestions? Gcollier Instruments and Amps 6 5th April 2007 10:50 PM
DIY guitar amplifier cabinet Gabster Instruments and Amps 7 9th January 2003 03:27 AM
Page generated in 0.15740 seconds (64.68% PHP - 35.32% MySQL) with 11 queries
