HV Direct Drive tube amp.
Old 23rd February 2007, 12:02 PM   #11
sasha is offline sasha  Canada
Hi gorgon53,
I am not sure what are You referring to when You say
"not enough current to supply the heater transformers stray
capacitance at the hf side of the spectrum".
I don't understand what heater trans. has to do with
capacitance or HF.
Anyway, my Acoustat X clone is working just fine with 6HV5
so I will stick to this design.
Regards.
Old 23rd February 2007, 03:31 PM   #12
gorgon53 is offline gorgon53  Finland
Hi Sasha
The heatertransformers secundary has a substantional straycapacitance to his primary (or screen) and his surroundings, usually a few hundred pf. Indirect heated tubes cannot sustain a high voltage swing between theyr cathodes and the heater. Therefore you would have to couple the transformers secundary to the cathode and supply all the ac-current demanded by the application AND the substantially high currents demanded by the transformers secundary straycapacitance at up to 20kHz at kV levels. This can only be done with BIG transmittingtubes. A few mA just wont do. Besides, even your suggested voltages are high, they are still a bit on the low side, up to 7kVpp would be needed for a Quad (for instance)
Old 24th February 2007, 03:13 AM   #13
I am trying to understand what You saying but
I am still little confused. You are probably referring
to capacitance between cathode and heater and
heater/primary to secondary of the transformer
something like two caps in series from cathode to ground.
Basically output will be loaded with additional capacitance.
Resulting capacitance will be smaller than cathode to heater alone
and this will not load output much more because ESL panel capacitance
is 1-2nF, ten times more than this parasite cap.
Acoustat is working in bridged mode so from 5kV
supply it is possible to get close to 10kVpp.
I don't know why it's working but it does.
Regards.
Old 24th February 2007, 04:47 AM   #14
Hi Sasha
Electrostatic speakers arent simple capacitors, gladly, otherwise you would need a reactive current of 1App at 8kVpp and 20kHz.
But straycapitances are!!! 1nF of stray needs 1App at said voltage and frequency.
just do the maths please.
Anyway, for your on safety, if those clearcut and simple things are a puzzle to you please stay away from this project until you have gained all the knowledge and understanding needed to takle such a dangerous project. I can tell you, I once have been hit by 12kV from a HV supply that could deliver 10Adc to the load and I am 1 of the lucky ones getting away alive (burned offcourse)
but Id rather be hit by a train than by high voltage again. If seen picturers of the remains of ppl not that lucky, in one the shoes where recognicable, the rest was black mush....
You see, its all about power delivered into the load (wich means YOU in a worstcase situation) high voltage from a TV set isnt quite the same than HV from a supply that can deliver serious current.
Oh, and I have not been careless when my exident happend, was just "lucky" enough so that several most unlikely and unforeseeable events all happend at the same...so safety is never safe enough...**** happens...for real
Old 25th February 2007, 02:25 AM   #15
Thank You for your concerns about my safety
but it is too late to be scared now since amp is
up and running . Regarding current requirements
for e-stats, there is almost no 20k signal in real music
spectrum hence no need for such current. Remember
we are listening the music not the signal generator.
Even at15k there is so little to be amplified that we
don't need monster amps, otherwise power supply
needed for it will be something like 10kW!
Why is so hard to believe that such amps are real and
work just fine and of course to be sold commercially
needed to be approved by government agency for home use.
Home use means that average Joe is exposed to "lethal danger".
Of course building of it is not for beginners and basic safety rules are
must. By the way I am " trained professional"so I did try it at home.
Old 25th February 2007, 03:52 AM   #16
Hi Sasha,
I looked at the circuit diagram of the acustat, from the drawing I could not say how they solved the heating of the upper tube, maybe they used highfrequency to cut down on the straycapacitance, or a very special designed transformer, no idea, but it is a problem that has to be solved before that thing has a chance to work....otherwise...to much sand in the gears (for my taste) and I would not be supriced if it is down by 10-20db at 20kHz...or...it get some lift by resonces at the hights.
You know, just recently I designed a universal-driver.
My goal was a simulated amplifier capable of delivering
at 20-20kHz and:
at least 800Vpp into 20-200pf and 100kohm,
with a thd better than 3ppm,
and 3th and higher harmoniclevel down by at least 120db,
a phaseshift below 3deg at the passband-ends,'
a outputimpedance of max. 300ohm,
a inputimpedance of min. 100kohm,
no internal slewratelimitations with said load and inputrisetimes of 1nsec,
highest possible outputcurrent (up to Ikmax of the tube) with square or triangle input
I found out:
I NEED A SEPERATE DRIVER, A SEPERATE KATHODEFOLLOWER TO FEED THE STRAYCAPACITANCE OF THE HEATERTRANSFORMER; OTHERWISE NON OF MY SET GOALS CAN BE MET!!!
I needed 8-12 triodesystems (including at least 2 very expensive E288CC) to achieve my goal (well, with the 12 tubes version I exeeded easely my goal in respect to linearity, but I had to cut down a little on the outputvoltage and phaseresponse)
The Supply had to be at least 1000V at 30-35mAdc.
Very high peakoutputcurrents (over 100mA) can be drawn,
but omparable high gridcurrents (up to 1/3 of the outputcurrent) are needed.
The 12-tube mufollower/white cathodefollower-triple tube-cascade I used can have a voltage AND current amplification of over 6000 without external feedback.
The 8-tube approach is a bit faster, distortionlevels can be met, it givs higher outputvoltage but has a gain of around 250 that is just a bit below the set goal for the input sensitivity, neither input nor outputimpedances can be met (there is not enough gain for any fb)
A external feedbackloop is not absolutely necessary, but of advantage to stablice the dc-level at the output, the same fb-loop can be used to adjust the inputsensitivity and impedances but it does not much affect the distortionlevels, especially the 3th and higher.
The higher millercapacitances of tubes other than the E288CC(paired for roughly comparable steepness) worsens distortionproducts in approximate relation to the increase in capacitance.
Now, if I apply my findings to your circuit Sasha, your tube is a good choice, you would not necessarely have to cascade it with a other tube because of the high gain, it also would be tuff to find a even steeper tube without parallelling (a 416 would be cool) but a cascode would have advantages in your circuit, BUT you need current, and when you intend to use a even somewhat conventional heating arrangement (for the upper tube) you will have to use a seperate cathodefollower (or any other suitable amplifier arrangement) for th, otherwise your poor little tube will run outta steam at the high frequencies and not produce full outputlevels at low distortion, youŽll get low output with high distortion instead.
Think of it
But, a amplifier could be build around lets say at least 3 of this tube, or better 5 + a few other tubes,
a amplifier with breathtaking specifacations that would be better than almost any solidstate amplifier, driving directly a electrostat, wow, it would be cool, would make other high-end stuff look like a pair of old shoes...
But, all nowdays safety requirements would be tuff to satisfy in a unit that could be safely sold to customers, seems almost impossible to me at the moment....
I wish I where younger and had enough time to dig deeper into all the probs involved, find solutions and build such a beast, or at least had a usable spicemodel for this tube and a young guy with enough expirience to be trusted in fiddling around with lethal high voltages to build it....
Old 25th February 2007, 04:17 AM   #17
Sasha, looks like whatever I say it would not keep you away from this project ;o)
Tell me, what are you trained in exactly?
I based my opinion on your capabilities on the fact that you said high voltage is not that dangerous because you have expirience with the high voltages of a TV set. Someone that think that the charge (and danger) of a maybe 500pf capacitor is even comparable to what you expirience when getting hit by highvoltage from a source that can send some serious current through you. Now, no trained engeneer, or tecnician with REAL HIGH VOLTAGE KNOWLEDGE, NOT EVEN THE MOST UNTRAINED RADIOAMATEUR WHO BUILDS HIS OWN TRANSMITTERS would think like you do in respect to high voltages.
In regard to a small amplifier driving a electrostat you are propable rigth, the signal MUST be much lower than it should be,
I presumed you want something better, better than transformercoupled systems can do, better than acustat...
Forgiv me, I admit I was wrong...
Case closed
Old 1st March 2007, 02:27 PM   #18
Hi, again.
When I said this 5000V PS is not dangerous I didn't mean
when plugged in but charge from PS capacitors after switched off.
Of course I am not getting even close to the circuit when
operational. Shock from 500nF at 5000V is nasty but not deadly.
Even voltage/current from step-up transformer widely used with e-stats can do some serious damage if touched when played loud.
Looking at PS of the Acoustat I can say it is anything but impressive,
which means no big current is needed for this real world application.
Sometimes when designing circuit we put our goals too high and
end up with conclusion it is hard or impossible to make it.
I am in no way expert in tube or any other circuits but I am good
in cloning and sometimes improving design.
Only big problem with Acoustat was premature tube failure.
When I look at original tubes (6HB5) specs I can't believe
they used this tube http://hereford.ampr.org/Tube4.php?tube=6hb5
I am sure You gonna laugh in disbelief when You see the specs.
How is this possible to work You gonna ask. Well it does, not very reliably but it does and even engineer from Acoustat who these days
offers very expensive upgrades to this amp does not change original tubes??? At least this is mine "non expert opinion" if I have right to one.
And this is why they have so much problems.
My next clone will include better OP amps, feedback caps and resistors.
I don't mind " sand " in this design since some of the best amps
are as we all know very " sandy". I am not very picky I just wonted
something better/cooler than step-up transformer.
Regards.
Old 14th March 2007, 11:53 AM   #19
knubie is offline knubie  Norway
knubie's Avatar
Hi Sasha
How's the calculations going?
To bad no-one would help you, I would be interested to!
I tried calculating the Totem pole coming from the TJC Push-Pull program, like your attachment earlier, but I'm not sure...
Proposition: Your Acoustat amp was driving your Audiostatic clones to ear splitting levels you said in another post!
Couldn't you then try using 6HB5's with a lot less voltage 1000V for example in totem pole configuration?
If it's stuck, force it... If it breaks, what the hell, it needed replacement anyways....
Amateurs fixing a fault: they succeed but then discover another fault in addition to the part they just broke....
Old 14th March 2007, 12:03 PM   #20
On Hiatus
SY's Avatar
I've direct-driven Acoustats from 1000V. Not enough.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
HV Direct Drive tube amp.Hide this!Advertise here!
ESL Direct Drive Atom666 Planars & Exotics 6 5th October 2008 08:09 AM
Direct Drive fun!!! Cobra2 Analogue Source 32 20th January 2007 02:23 AM
Another direct drive thread maudio Planars & Exotics 18 25th June 2006 06:53 PM
Direct drive amp schematic Bazukaz Planars & Exotics 15 14th December 2005 09:04 PM
ESL Direct Drive SS amp jgwinner Solid State 34 30th August 2004 06:42 PM
