Berning output buffer
Old 16th October 2005, 03:12 AM   #11
On Hiatus
SY's Avatar
In that preamp (which I used for most of the past 20 years), I used a -15V negative rail.
To answer the second question, I note that when I retired my preamp, the linestage that replaced it was the Heretical, which is indeed a cathode follower with a current source. I use a servo almost identical to that in the TF-10. And in later preamps, Berning reverted to a cathode follower with a large resistor down to a B- rail, still servoed.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Berning output bufferHide this!Advertise here!
IRF9530 as pre output buffer wleediy Solid State 11 23rd January 2008 09:36 AM
Difference between 6JN6 (Berning output) and 6JB6 tubes? GordonW Tubes / Valves 1 8th January 2008 04:00 PM
Berning MicroZOTL wanted Studley Swap Meet 1 24th December 2007 05:55 AM
Berning P-1 Preamp kmtang Tubes / Valves 8 22nd May 2005 05:07 AM
Anyone using berning micro-ZOTL? mulebarn Multi-Way 3 7th March 2004 09:44 PM
