diyAudio Sponsor
Old 17th October 2005, 06:23 AM   #11
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
here's mine i designed for frank's ultimate tube preamp:
Old 17th October 2005, 11:47 AM   #12
Jay is offline Jay  Indonesia
Miles Prower, thanks for the explanation. Now I know why my tube amps used small caps I was thinking about my pre-amp supply I think 100uF is not big for a pre-amp is it? Hmmm... so where would the amp source the current for bass slam?
Old 17th October 2005, 12:48 PM   #13
Sherman is offline Sherman  United States
Use a small cap for the first cap after the rectifier tube. Then use progressively larger caps through the filter section.
Using a 5U4-G with a max cap value of 40uF I built a filter section using 5U4-G -> 40uF -> choke -> 55uF -> resistor -> 80uF. The VT rectifier seems perfectly happy with this arrangement and there is sufficient current reserve.
--Sherman
Old 17th October 2005, 12:53 PM   #14
philipbarrett's Avatar
Send a message via AIM to philipbarrett
Thanks all, this is great stuff. I think PSU design looks simple but is anything but.
What value would you recommend for the 1st cap? Is there an altogether better way of filtering here?
One more question on PSUD2; is CT transformer voltage rated to center or between the outputs (250-0-250 would be a 250V or 500V)?
Thanks again.
PB
Old 17th October 2005, 01:08 PM   #15
Thanks again.
PB
According to the data sheet the max cap value for a cap input filter is 50uF.
In PSUDII the voltage is from secondary to CT, that is if your trafo is rated at 250-0-250 then use a value of 250 in PSUD.
--Sherman
Old 17th October 2005, 06:57 PM   #16
opik is offline opik  Indonesia
opik's Avatar
Originally posted by Miles Prower
Here's something else that will come in handy for this: Rectifier Applications Handbook
thanks a lot!
regards, opik
Old 18th October 2005, 01:35 AM   #17
Tony's Avatar
frank"s ultimate tube amps uses big caps:
12bh7a_srpp
350volt psu
i made a psu using ss parts shown in my post above. it is a voltage doubler using mr4100 rectifers, large caps, and transistor series pass element.
Old 18th October 2005, 01:50 PM   #18
Joel is offline Joel  United States
Joel's Avatar
Default "frank's ultimate tube preamp uses big caps..."
Yes, but it also has a 1A power transformer, and a solid state bridge rectifier.
Old 18th October 2005, 11:03 PM   #19
Tony's Avatar
Default Re: "frank's ultimate tube preamp uses big caps..."
fedgrove must have felt that big transformers and ss bridge provides for better regulation! very desireable for srpp amps.
costs aside, makes a lot of sense to me.
Tube PSU question Greyskale Power Supplies 8 27th February 2008 09:06 AM
What can I do with these? (tube and OPT question) needtubes Tubes / Valves 7 8th March 2005 01:01 PM
WE old tube question filippo22 Tubes / Valves 6 26th December 2003 07:26 PM
Tube Question, what the....? Rino odorico Tubes / Valves 15 11th November 2002 09:14 PM
Tube CAD Question Aud_Mot Tubes / Valves 0 6th October 2002 03:53 AM
Page generated in 0.14210 seconds (63.90% PHP - 36.10% MySQL) with 10 queries
