diyAudio Sponsor
Old 15th October 2005, 07:04 AM   #1
Tyimo is offline Tyimo  Hungary
Default Which SE-ECL82 amp to build?
Hi!
I was looking for a nice and simple SE amp with one ECL82 per side and found two attractive circuits.
I would like ask the experts about these designs:
-are they operate in Class A?
-has any negative fead back in the circuits?
-which one is better? :-)
Thanks and greets:
Tyimo
Old 15th October 2005, 07:09 AM   #2
Here is the another competitor!
Note. Power supply removed from schema -- to dangerous to contemplate
Old 15th October 2005, 07:41 AM   #3
PRR is offline PRR  United States
PRR's Avatar
Yes, obviously.
No. (I won't count the cathode resistor in the first one.)
They are essentially THE SAME. Draw them both in the same style: very minor differences.
One BIG difference: #1 does not show a power supply, #2 does, and the #2 power supply as drawn is a death trap!!! It shows one side of the wall-power line connected to chassis. There no indication which side is utility-ground. It is uncertain which wall-socket pin is grounded (60% of my kitchen outlets had black and white reversed). The chassis is exposed to the users at the input connector, which makes the whole hi-fi system "electrically HOT". It can kill you or your children. And as drawn, turning the power switch Off ensures that the chassis will be "hot". Do not build that power supply as shown!!!
Old 15th October 2005, 08:44 AM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Please moderators, remove that awfully dangerous schematic, as PRR said.
Old 15th October 2005, 01:35 PM   #5
And here is the first one's PSU:
Old 15th October 2005, 05:04 PM   #6
Giaime's Avatar
Originally posted by Tyimo
Giaime: here is a corrected schem.
That is always no-good, the B+ runs directly from the mains. You should use an isolation trasformer between the diode and the mains, to mantain safety rules. And also a half wave rectifier is no good. Try to redesign the PSU using PSUDesigner.
Old 15th October 2005, 06:37 PM   #7
kevinkr's Avatar
I think I would just build the more recent of the two circuits, supply decoupling looks to be marginally better in the newer design.
If you do build the earlier one do get a power transformer with about a 180-200V secondary as well as a filament winding. You can use a bridge rectifier, bear in mind the original halfwave rectifier would have dropped significantly more voltage than a full wave bridge.
The old power supply design as previously stated is extremely hazardous to put it mildly.
Kevin
Old 15th October 2005, 08:47 PM   #8
frugal-phile(tm)
planet10's Avatar
How about Morse's Gnat?
Pics of my 6BM8 - The Gnat....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th October 2005, 10:18 PM   #9
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
search for "Aleksandar Kitic" in this forum.
LH84 (if I remember OK ) looks promising
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 16th October 2005, 05:52 AM   #10
Hi!
Giaime! Yes, you are right! I looked only the main-audio circuit section and not the whole circuit with the PSU... That PSU design was realy a "deadly joke" Thanks for the moderators that removed it from the schematic!
Kevin: Thanks! Which one do you mean: the Noel82, with coloured schem ? I would anyway build a better PSU for this amp.
Greets:
Tyimo
beginner's ecl82 skyraider Tubes / Valves 30 18th October 2011 02:46 PM
Ecl82 alexandar888 Tubes / Valves 15 10th May 2009 07:39 AM
ECL82 Headphone amp mod_evil Headphone Systems 9 8th April 2007 10:31 PM
First ECL82 amp probs. the_rod Tubes / Valves 2 2nd January 2007 03:21 PM
Page generated in 0.12834 seconds (74.81% PHP - 25.19% MySQL) with 11 queries
