diyAudio Sponsor
Old 14th October 2005, 10:06 AM   #1
bobhayes's Avatar
Default Typical 2A3 hum?
Hi all,
I've been listening to my 2A3 amp for about a year, and love it. But I recently plugged my TV into it to watch a film, and the hum is unbearable for movies because of all the silence in films.
I just wondered what the typical hum figures are for these types of amps.
I have 10.8mV left and 10.6mV right at the speaker outputs, when loaded. Is this more than should be expected from sovtek 2A3's?
I know its originating in either the 2A3's or the output transformers and reckon this is typical filament hum, so I thought I'd just check.
It's 100Hz and is there whenever I switch the power on. It remains when I pull the rectifier, so it must be the AC filaments right?
It also remains when I pull the driver tube, and only disappears when I pull the 2A3's. It is an octave above the 50Hz hum I get when I wind the hum pots to one end.
Any information would be greatly appreciated, if only to put my mind at rest.
Thanks, Bob
Old 14th October 2005, 10:15 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Bob,
I have read that 2mV hum on your output is attainable even with AC heated filaments.
Does your filament supply have a hum pot?
Bas
Old 14th October 2005, 10:23 AM   #3
bobhayes's Avatar
Both channels heve hum pots.
I can minimise the 50Hz hum, but am left with 100Hz hum remaining both channels.
I read through some other posts but did not find the exact problem I described above.
Old 14th October 2005, 10:28 AM   #4
SvErD is offline SvErD  Norway
SvErD's Avatar
Do you have cable-TV? Does the hum go away if you pull out the antenna-cable?
Then you need a galvanic isolator.(Balun?)
I don't suffer from insanity, I enjoy every minute of it!
Old 14th October 2005, 10:31 AM   #5
Probably a ground loop somewhere...since PSU ripple hardly ever is a problem. Is it a homemade amp?
Old 14th October 2005, 10:39 AM   #6
bobhayes's Avatar
Thanks SvErD,
The problem is the same whatever the source, or even without one, so I don't think the TV is the problem.
Bas Horneman,
Yes, the amp is home built. Where should I look first for ground loops?
It's such a simple circuit (JE Labs/Angela 6SL7/2A3) and as far as I can tell there should be no ground loops.
It is however, built on an aluminium chassis. Could the ground plane resistance (one ohm end to end) play a role in this?
Old 14th October 2005, 10:50 AM   #7
Hi Bob,
I'm still learning about grounding..it's not easy. What does your current grounding scheme look like? Star ground has worked well for me...except in the last amp which I built for someone else...someone else took over and fixed my mess... and made a seperate star earth for signal and psu and joined the two star earths..worked better...because you don't want large currents near small currents...
Old 14th October 2005, 11:00 AM   #8
bobhayes's Avatar
Bas,
Every component which requires grounding is grounded by it's lead (or short wire) directly to the chassis, at the closest socket or transformer mounting nut.
The chassis layout is (from left to right):
Mains In
Mains Tx
Mains switch and fuse
Rectifier
Choke and HT caps
Speaker terminals
Output Tx's
2A3's
6SL7's
Volume and inputs
Its fairly conventional in order to eliminate such problems.
Old 14th October 2005, 11:19 AM   #9
Hi Bob,
A picture would say more than a thousand words..
Because from your description...it does indeed sound as if that could be a problem...In Morgan Jones's book he describes how moving one wire 2 centimeter solved the hum..
Bas
Old 14th October 2005, 11:39 AM   #10
bobhayes's Avatar
Which wire?.. He,he,he!
Looks a mess, doesn't it?
typical unwanted amp byproducts gearheadgene Class D 12 17th January 2008 06:19 PM
Not a typical MKIII Dynaco. Duo Tubes / Valves 10 22nd January 2007 12:25 AM
A typical KT88 tubes oasis_oasis Tubes / Valves 0 18th January 2007 02:31 PM
Just your typical DIY enclosure.. ScottG Multi-Way 2 10th July 2005 10:44 PM
Typical newbie question michael Chip Amps 1 19th February 2004 10:47 AM
Page generated in 0.17239 seconds (58.02% PHP - 41.98% MySQL) with 11 queries
