So what are some good 7-pin, hi mu, low noise/microphonic tubes?? - Page 2 - diyAudio
Old 12th October 2005, 07:37 PM   #11
Tom Bavis's Avatar
I have a copy of an old article on using the 6AU6 as a triode with the plate grounded (as a shield). Screen is connected as plate. If I can dig it up I'll post it on my web page.
Old 12th October 2005, 07:52 PM   #12
aletheian's Avatar
Cool man,
Let me know if you find it.
Old 13th October 2005, 02:13 AM   #13
Tom Bavis's Avatar
http://www.audiophool.cjb.net/Techno.html
Scroll down a ways... at the end of the Tube Data section
Old 13th October 2005, 02:23 AM   #14
aletheian's Avatar
Nice article. I'll have to mess with it some.
Old 13th October 2005, 08:30 AM   #15
Miles Prower's Avatar
I would also add the 6CB6A. This small signal pentode works very well as a DC amplifier for a series pass regulator, and a CCS. The characteristics look pretty good for use as a small signal amp (haven't tried that yet).
6AQ5A: basically a down rated 6V6 with very similar characteristics (including some secondary emission kink, so keep the Vpk up). Works well in triode configuration, and as a series pass regulator.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 13th October 2005, 10:47 AM   #16
Geek's Avatar
The 6AQ5A also has 1/2 dozen or more variants - availability is super
I'd like to add to the 6CB6A as a largeish signal driver. Need a little pentode (or tioded) to push along some 6L6's in AB2? Try some 6CB6A's after your phase splitter.
It also makes a nice tube as the top section in a mu-stage. Trioded or pentode, it'll sound good (microphonics depend on brand) and the high h-k voltage simplifies the filament supply (no need for floating filaments with 320V or less Va)
Old 13th October 2005, 05:03 PM   #17
aletheian's Avatar
Great info. I'll definately pick up some of those.
Microphonic s2kov Tubes / Valves 24 7th June 2010 05:20 PM
microphonic sub-miniature tubes? space-cake Tubes / Valves 11 10th October 2008 03:02 PM
are these tubes any good ????? istari knight Tubes / Valves 5 6th September 2005 05:46 AM
Good tubes for Luxman pre-amp Andypairo Tubes / Valves 9 16th December 2003 07:12 AM
Good Low-noise op amp? Michael Rothacher Solid State 3 11th August 2003 07:24 PM
Copyright 1999-2017 diyAudio
