Audio Note M7 Line Preamp?? - Page 2 - diyAudio
Old 20th May 2006, 08:19 AM   #11
KYW if you’re there:
for the M7 to sound really good, does it need big $ components (in the way that much of the charm of the Ongaku probably derives from its exotic components)?
Cheers
Old 20th May 2006, 11:47 AM   #12
Previously: Kuei Yang Wang
Konnichiwa,
You do need a reasonable level of component quality, but surprisingly, most of the components Kondo used are fairly unexceptional, except for Tantalum resistor throughout and his own handmade silver capacitors.
I would suggest that using standard Metal Film resistors (2W) and Tinfoil & Polypropylene coupling capacitors will go a long way.
AN UK has now got Silverfoil & Mylar coupling capacitors but the prices are somewhat high....
Sayonara
Old 20th May 2006, 12:52 PM   #13
Thanks KYW
Assuming you can adequately compensate for the big differences in gain (I have three systems in different stages of development), your thoughts on how it might sound compared to
A finely tuned hybrid:
www.aksaonline.com/products/products_GK1.html
A device switchable from rose coloured glasses to passive, etc:
www.mapletreeaudio.com/magic5.htm
very clean and borrowed from the past, er like much blues music:
The Heretical Unity gain line stage
A supposedly “blistering fast” ring-in
www.transcendentsound.com/preamp%20kit.htm
Thanks again
Cheers
Old 20th May 2006, 01:03 PM   #14
Konnichiwa,
The M7line sounds nice enough, very much "Kondo" but slightly on the warm side.
I cannot at all compare to the others, I have not heard them.
I personally prefer passive linestages nowadays, but the M7line sounds very nice for such a simple design.
Sayonara
Old 20th May 2006, 01:36 PM   #15
Default to esimate laquer
Thanks KYW, that is helpful
On another note, after reading your favourable posts on the subject, I emailed Dieter Ennemoser re C37 and have yet got no response, your thoughts:
“I have several paper cone drivers of different sizes (6.5 - 15").
I understand that it does vary, but as a starting point, on average - how many ml of C37 does it take for a good result on eg a 6.5” paper cone mid?”
Cheers
Old 15th August 2006, 02:56 AM   #16
Originally posted by JPS
I use 9AU7 for this circuit in an old compauter supply.
Cheap and sound good.
PapaNohn
Old 15th August 2006, 02:57 AM   #17
Another pictures
PapaNohn
Old 21st January 2009, 12:21 PM   #18
LENB is offline LENB  United Kingdom
Regarding the cloned Kondo M7 preamplifier, can l straight swap
a12AU7 for a 6072A valve, the original used a 6072A, this answer
was a reply given by a member Kuei Yang Wang back in 2002 to a
member of the forum but he didnt say whether you could
without adjusting the ciriciut
can anybody help.regards LenB
Old 22nd January 2009, 06:05 AM   #19
a more suitable plug and play tube to replace the 6072 would be 12at7(ecc81), without having the need to change any parts of the circuit.
Old 22nd January 2009, 08:45 PM   #20
smbrown is offline smbrown  United States
smbrown's Avatar
I built the 6072 version a number of years ago - it was my first tube preamp. I used tant resistors and AN caps (not silver). I built it with the same choke loaded supply that was in the AN schematic, tube rectified, etc. You know, it was okay, but I don't remember it as a giant killer. Overall I find I like an anode follower better. Simple and direct. Of course, highish output impedance.
Audio Note Preamp Circuit a good guess... ThorstenL Tubes / Valves 4 6th June 2007 11:09 PM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First Vortex Tubes / Valves 1 2nd February 2004 12:31 AM
Copyright ©1999-2017 diyAudio
